I have a Sony Vaio PCG-9PGL series and a Panasonic Camcorder PV-DV400 Mini DV. I think I have the right plug, the DV Interface IEEE 1394 it plugs into the camera, but it will not fit into any place on the laptop. What is going on? Does this mean that is actually is not a DV Interface IEEE 1394? Do I need an adapter for this plug for it to fit into my laptop? Please advise.
Thank you,
Megan
P.S. I really am new to computers and copying the videos to them, so easy to follow instructions are appreciated!!![]()
Results 1 to 10 of 10
Thread: Mini DV
Firewire ports come in two styles, 4 pin and 6 pin. Most commonly the camcorder has a 4 pin connector and the computer has a 6 pin and you probably have a 4 pin to 6 pin cable. That laptop has a four pin iLink port. You need a 4 pin to 4 pin firewire cable.
Buy My Books
There are two types of DV socket - basically a full size socket and a mini-socket designed for laptops and small devices. Makes sure you have the right cable.
Does your laptop actually have an IEEE-1394 port?
If not get something like this.
http://www.newegg.com/Product/Produc...+PCMCI&x=0&y=0
If you want more advice ID your laptop.
She did.Originally Posted by edDV
It has a 4 pin iLink port.Originally Posted by Cess"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
Missed that. Vaios have th 4pin yep. Labeled ILink.Originally Posted by gadgetguy
Ok, thank you! What I have, I think must not be right. I mean, I have 2 cords, one end of one fits into the camera but not into the laptop (not long enough), the other one fits into the laptop, but not the camera (the camera end is too big). Maybe I should take a picture of them?
Edit-the length of the cord going into the laptop is okay, but the length of the hook up into the laptop itself is the issue. Hope that makes sense??
Try checking out this website:
http://www.simplydv.co.uk/infobase/about_firewire.html
Hopefully this will give you what you need.
Dave
You only need one cord, it can have either ends. What's important is that it fits the ports on your computer and camcorder. According what was posted above the ports on your cam and computer are both 4-pin. they should match this picture exactly, note that one type of USB port is similar but the divot in the center will not be there. If you have a 4-pin port on your computer you only need a 4-pin to 4-pin cable.
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum CapturingReplies: 4Last Post: 8th Feb 2011, 17:27 -
Matrox MX02 Mini or Matrox MX02 Mini Max
By Cingular in forum CapturingReplies: 0Last Post: 14th Oct 2009, 20:27 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 02:11
