Hello,
My camcorder produces MTS files (it's Sony HDR-SR7).
The utility that came with it can create AVCHD DVDs, but not very well (there is a pause between each sequesnce).
How can I join MST files without recompression ? (with recompression I can use Pinnacle Studio 11.1 beta)
Thank you.
Results 1 to 10 of 10
Thread: AVCHD - join MTS files
Lotsa them -
Tssplitter also joins nicely. You might have to rename the extensions to .TS, but maybe not.
Thank you for your replies.
I tried VideoReDoPlus-2-5-6 but it's unable to open the files.
I has success with TSSplitter, HOWEVER when I play the join file, there is a 3 seconds pause between sequences....
Is there another tool that I can try? Thank you.
I have been looking around and am currently very happy with Elecard's Converter Studio AVC HD. Very fast and easy. Instructions are in this thread: http://www.elecard.com/forum/viewtop...in+avchd+files
I just tried it with TsMuxer on some AVCHD clips from a Canon HG10. You'll need to rename the extention to "m2ts" and use the "Append" to join them. Output to m2ts and they will play fine with no delay.
There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
WHen I use Converter Studio AVC HD, I don't need to rename anything. It reads either .m2ts or .mts.
Whoops, wrong thread. Sorry
Elecard's Converter Studio AVC HD did not join properly (output has audio but video is black)
TSMuxer seems to work, thank you for your message (I only tried with 2 files)
I will try with a few hundred files and check how it works
cmichel04,
It has been a while since your post but have you had any luck with Tsmuxer with MANY files? I tried it with 10 files. The video was good but the audio had a delay at the end.
Yesterday, when I searched "join mts" in Google Video, I found this:
http://www.youtube.com/watch?v=MFuTXq92IR8
The video shows how to join mts files with Tsmuxer and eac3to and the description says that eac3to is used to solve Tsmuxer's audio out-of-sync problem.
I followed the method described in the video and it worked -- I used this method to join 10 mts files and there was no audio delay at the end.
The method is a bit complicated though. Does anyone know other simpler and free ways of joining mts files?
Merge HD MTS (AVCHD) files
By foxnews in forum Video ConversionReplies: 9Last Post: 28th Jun 2011, 08:18 -
AVCHD MTS files - 1.6 GB on card, but only 8 MB readable
By moxiecat in forum Camcorders (DV/HDV/AVCHD)Replies: 9Last Post: 22nd Feb 2011, 14:10 -
Create a playable AVCHD BD-R from .MTS Files???? Please Help!!!
By realace2 in forum Authoring (Blu-ray)Replies: 0Last Post: 2nd Dec 2010, 06:32 -
does ffmpegx work with MTS (AVCHD) files
By jps61 in forum ffmpegX general discussionReplies: 2Last Post: 9th Apr 2010, 12:13 -
Any good utility to join m2ts (or MTS) from AVCHD camcorders?
By sebaz in forum EditingReplies: 4Last Post: 17th Jan 2010, 11:10
