VideoHelp.com Forum
  1. Hi All,
    I'm creating my first DL DVD, using SonyVegas, and DVDLab with CCE. When I open CCE, I have a choice of using 16-235 or 0-255. I've been using 16-235 for TV Playback, but would like for my customers to use it on their computers as well. Are there any standards in this area? What are the commerical DVD using?
    By the way, my video is NTSC, and interlaced, in SonyVegas.
    Thanks.
    Matt
    I do not think most monitors or TV are able to display pure black or white so either setting will do. On top of that, if your video is from DVD camera, than 0-255 info will not be there to begin with.
  3. Originally Posted by tinker
    My video consist of 4 seperate videos.
    Video1 Source - Sony DV Cam
    Video2 Source - VHS Capture
    Video3 Source - VOB Files/DVD
    Video4 Source - Pictures/SlideShow from Canon 20D camera.
    So would it just be best to use 16-235, in this case?
    Thanks.
    Matt
    If your source is YV12 or YUY2 it doesn't matter which you use -- the setting only effects the conversion of RGB to YV12 by CCE.
    If your source is RGB you should use the 16-235 setting. Except in the specific case where you intend to create blacker-than-black and whiter-than-white -- as when making black level or white level video test patterns from BMP images. Or when you know your RGB source has luminance already in the 16-235 range (you usually have to go out of your way to get this).
    In short, use the 16-235 setting (which means: convert incoming RGB sources from luminance levels of 0-255 to YUV luminance levels of 16-235).
  5. Originally Posted by jagabo
    My source with all the videos added is RGB because I'm rendering from Sony Vegas 7d which only works in RGB colorspace. I turned off the Luminance feature in Vegas and will just let CCE do this for me.
    Thanks!
    Matt
    If Vegas can convert YUV to RGB and retain the luminance levels in the 16-235 range you should leave your video like that and use the 0-255 setting in CCE. This will prevent the loss of blacker-than-black and whiter-than-white portions of the picture (which most video has a little of, especially the latter).
  1. Replies: 188
    Last Post: 29th Sep 2011, 20:18
  2. convert .mkv from level @5.1 to level @4.1
    By florinus in forum Newbie / General discussions
    Last Post: 29th Nov 2010, 15:33
  3. AVC level 5.1 to AVC level 4.1 conversion?
    By tomisoft in forum Video Conversion
    Last Post: 26th Dec 2009, 20:18
  4. CCE Luminance setting -- clarification needed
    By eclipse95 in forum Video Conversion
    Last Post: 30th Sep 2009, 10:12
  5. DVD Luminance Value - How to do it right?
    By SCDVD in forum Newbie / General discussions
    Last Post: 7th Aug 2007, 20:42
