VideoHelp.com Forum
    Hi All,
    I do not have a tv in my room but a computer. I want to play some dvd movies using my pc monitor as a display. I look at the product rj-200bk dvd player by rjtech and it has an vga output. I wonder if I can connect rj-200bk to my pc monitor and play some dvd movie. Any help will be appreciate. Thanks.
  2. Member edDV's Avatar
    Why not play the DVD from the computer?
    http://www.epinions.com/pr-RJ_Tech_R...splay_~reviews
    http://www.kiva.org/about
    Playing the DVD from the computer is not convenient to me. Sometimes, I place the dvd in the dvd-rom and it's just spinning. It makes me frustrated. and to watch a movie, i have to boot the computer. Not like the regular dvd player, you just put it in and play. Thanks.
  4. Member wulf109's Avatar
    I had an RJ Tech DVD player and I did hook it up to a computer monitor and it worked well. I needed to hook it upto a TV to access it's menu and change it's output to VGA and then hooked it upto the computer monitor. Sounds like your DVD-ROM is defective,you might want to install a new DVD-ROM before buying a DVD player with a VGA output.
  1. connect monitor far
    By ecos in forum Newbie / General discussions
    Last Post: 25th Jan 2011, 20:31
  2. Connect LCD PC Monitor to DVD Player
    By tsloby in forum Newbie / General discussions
    Last Post: 19th Nov 2009, 11:01
  3. connect pc to another room monitor
    By blader18 in forum Media Center PC / MediaCenters
    Last Post: 30th Sep 2009, 15:19
  4. How to connect a monitor to a digitanl cable box?
    By Latvian in forum DVB / HDTV
    Last Post: 3rd Dec 2008, 00:47
  5. Connect DVD Player to monitor
    By jpc82 in forum DVD & Blu-ray Players
    Last Post: 22nd Jul 2007, 07:54
