Hello,
I have a couple of downloaded series in AVI format (and I believe they have DivX codec) that I wanted to burn onto DVD. The episodes are each about 22 to 25 minutes long. I don't know anything about DVD burning software, but I was considering getting Ulead DVD MovieFactory 6 (the standard edition), because it's not too expensive, and it looked like it could be a good one.
I have a few questions about this software:
1) Is it any good to begin with? haha..
2) Are you able to burn multiple episodes to the DVD, or are you forced to use only one video file per DVD?
3) With this software, are you able to use video files from your computer, or does video have to be ripped from an already existing DVD?
I have a feeling that the last question probably has an obvious answer, but I'd like to know anyway. Haha.. I feel sortof dumb asking, but I'm very new to all this DVD burning stuff.
Thank you in advance!
I use version 4:
Originally Posted by cheeseandcrackers -
Heck, I'm still using version MF2 and the same things apply...
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
In addition to what has already been mentioned, the recent version 6 Plus also adds basic HD-DVD Authoring, and can capture directly to Blu-ray disc. There's also a new feature called "Edit Room" -- which allows you to easily add intro/outro/titles to a clip to spice it up a bit. You can also do some manual edits (not as powerful as VideoStudio, but just enough to let you do some basic editing).
Menu creation is template/wizard driven. There's a good set of templates, and you can even create your own using Ulead's PhotoImpact.
Regards,
George -
Thank you; you all have been extremely helpful! I appreciate it.
Adding 'copyright' info to video clip in Ulead DVD Moviefactory 6
By colinb1 in forum EditingReplies: 3Last Post: 19th Apr 2011, 07:13 -
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 13:42 -
Ulead DVD Moviefactory 6 Plus (trying to get to grips after UDVDWorkshop2)
By dvdfever in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2009, 20:01 -
Joining in Ulead DVD MovieFactory - does it lead to worse quality?
By rosbif08 in forum EditingReplies: 2Last Post: 6th Aug 2008, 21:32 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 10:43
