VideoHelp.com Forum
    hello all,
    i have a canon pixma mp600 and i am using canon's CD Label Print software. I am running in to one problem. I use Hub Printable DVD's and the software won't let me reduce the inner diameter to 17mm, it sticks at 33mm.
    any ideas, suggestions???
    thanks.....dave
    I believe there IS a way to change the inner dia in Canons software but I've forgotten how. A better solution, IMHO, is to get Acoustica's CD label print program. Excellent program! I use it with my Canon i960 for covers and my ip5000 to do the discs. Download the trial from Acoustica here: http://www.acoustica.com/downloading.asp?p=8
    File>Select Paper>New(bottom of screen)>type the inner and outer diameters......
    Hope this works..It only took me two months to come across that stupidity....
    @pijetro, THANK YOU, IT WORKED...i can not believe the stupidity within this canon program. you click on adjust circle size and you would think that would be it, right.....again, thanks, you helped me...
    @mowermanEd, i just tried the program you suggested, very good
    just can't wait to get the tray i ordered from e-bay....i am done with epson!!!!!!!!!!! i tried the epson RX580 and all it did was consume ink and make a lot of noise, this Canon MP600 is awesome....
    thanks again, dave
  1. Replies: 36
    Last Post: 24th Apr 2011, 14:39
  2. Difference between Canon Vixia HF-20 vs Canon HF-S20?
    By Wink in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 20th Nov 2010, 16:46
  3. Canon Rebel xti + Canon HV30 vs. Canon Rebel T2i
    By assman24 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 17th Jun 2010, 11:47
  4. Replies: 7
    Last Post: 4th Sep 2009, 18:58
  5. Canon XH-A1 or Canon XH-A1S?
    By ProducerHarley in forum Newbie / General discussions
    Last Post: 12th Feb 2009, 22:34
