VideoHelp.com Forum
Thread: psp and mp4's
    i want to convert a video file so i can play it on my psp. i understand i need to convert it into an .mp4. but what are the settings i should use like the bit rates and the frame rates and the resolution and the aspect ratio. what the heck is all that stuff and how do i know what size to have.
    thanks.
    You use a converter that has psp profiles like psp video9. You can then check what settings it uses and use in other converters.
    thank you but what are the best settings to have which will give high quality play back.
    You have to factor in the size of your memory stick and how large you want the converted file to be.
    I upgraded my PSP Video 9 to version 2 and it supports 480x272. This is the native resolution of the psp and firmware 3.40 and up supports playback of this resolution off the memory stick.
    I've been converting episodes of The Shield so I can watch them during my commute to and from work. So far I have tried 320x 240, 368x208 and 480x272. It goes without saying that 480x272 gives you the best results as far as visual quality. The Shield's native aspect ratio is standard tv or 4:3 but the PSP does a great job of displaying it when encoded at 480x272.
    My settings are mpeg4 avc 480x272. I dropped the default video bitrate from 768 down to 576, kept the audio at 128kbps and increased the volume 500% (not as loud as you may think). The file size for approx 45 minutes of an episode is around 200-230 mb.
    The end quality is good.. not stellar .. more a couple of reasons. First, the source files were already ran thru DVD Shrink. Then factor in that the Shield is shot with a grainy filter. But the end result is very watchable.
    If you want to convert a movie then go with the avc 480x272 setting, keep the default 768kbps video rate, use the 2 pass setting and make sure the source file is a direct rip with no compression.
    I havent tried any movies yet, but now I am curious.
    Let us know how it goes.
    NEC 3500AG - Firmware 2.TG
    LiteOn 16P9S - Firmware FS09
    Taiyo Yuden 8X, FujiFilm 8X YUDEN000T02, Phillips 8X CMC MAG-E01-000.
    DVDDecrypter, DVDShrink, DVDFab, Nero 7
    Hauppage WinTV PVR 150
    Dscaler, TMPGEnc Plus/Author, Canopus ProCoder, CCE.
    thank you so so much. ill let you know what happens.
    thanks for your help karelj
  1. Convert VOB file to MP4 (PSP)
    By HunterD in forum Video Conversion
    Last Post: 5th Mar 2010, 02:39
  2. PSP(MP4) Video Conversion...
    By Nizomi in forum Newbie / General discussions
    Last Post: 11th Oct 2008, 03:53
  3. help converting MKV to MP4 for PSP with subs.
    By jag125 in forum Video Conversion
    Last Post: 21st Jun 2008, 04:08
  4. mp4/psp sounds problems
    By Nick1982 in forum Newbie / General discussions
    Last Post: 21st Jul 2007, 15:22
  5. MP4 (PSP) EDITOR help
    By efiste2 in forum Editing
    Last Post: 29th Jun 2007, 13:54
