VideoHelp.com Forum
Results 1 to 14 of 14
    Ok, this just started happening, it never happened before until last night and I have tried everything and looked everywhere but I cant seem to find a resolution. Ok, so when encoding something with XviD in VirtualDub I do a dual-pass encode. On the 2nd pass I enter in my desired bitrate into the appropriate space under the settings (usually something like 953 as I want a 30min episode to come out to 175mb's) My encodes used to come out to somewhere around 175 (between 170 and 180mb's). Now when I encode using the same bitrate it seems that xvid just picks what ever bitrate it wants. Sometimes the final file ends up being 2801 (around 350mb's) or sometimes its 654 (around 100mb's) and I dont know why it is doing this. Can anyone help me?
    PS. I have attached a picture of my settings right below:
  2. it's a problem with the quantizer i believe try 2,31 instead of 1,31
    don't know how or why but i have the same problem than you if i keep 1,31 ad encode in 2pass
    TheMaster Rules ;)
    where do i change the settings from 1,31 to 2,31? please help me! i dont know what to do.
    can someone please help?? im going nuts not being able to encode
  5. Mod Neophyte Super Moderator redwudz's Avatar
    I don't know about themaster1's recommendations, but those settings are in 'Quality preset>User defined>more>Quantization' when you configure the Xvid codec.
    And welcome to our forums.
    ok well i have tried this and it doesnt fix my problem...any other suggestions?
    re-install,
    try another xvid version.
    I have seen the Xvid codec get "stuck" in a mode where it doesn't deliver the desired bitrate (it's been a while since I've seen this happen though). Try the following to unstick it:
    Press the Load Defaults button and try your 2-pass encode again with the settings you want.
    If that doesn't work, uninstall the Xvid codec and resinstall it again.
    i have done all this and it still wont work. I dont get it
    Try deleting the registry entries.
    HK_CURRENT_USER\Software\GNU\XviD
    i dont know how to get there?? im using windows vista
    Start -> All Programs -> Accessories -> Run
    type in REGEDIT and press OK
    From Regedit drill down to the indicated key, right click on XviD and select Delete.
    ok thanks ill try that now and let u know how it goes
  1. Replies: 3
    Last Post: 8th Dec 2011, 15:47
  2. VirtualDub -- XviD file size problem
    By higgins327 in forum Video Conversion
    Last Post: 29th Mar 2011, 16:05
  3. Xvid bitrate and file size problem - Heeelp!
    By Salinas in forum DVD Ripping
    Last Post: 10th Mar 2010, 17:05
  4. Xvid Encode by File Size Problem
    By hech54 in forum Video Conversion
    Last Post: 1st Jul 2008, 11:45
  5. Replies: 3
    Last Post: 26th Dec 2007, 00:08
