I am having VirtualDub crash on me when I try to open Huffyuv AVIs. Does anyone know how to uninstall it? When I go to uninstall it, Windows Control Panel says there has been an error and asks me if I want to remove it from the Add/Remove programs, so Im totally stuck.
Thread: How can I uninstall Huffyuv?
GAV
Go to c:\Windows\System32 and delete HUFFYUV.DLL. You may need to do it right after booting (before any program has used it).
Thank you. Is that all I need to do? Because I think I did this before, reinstalled it, but still had the same error (VDub crashing).
GAV
Do I do these things after removing the .DLL file?
GAV
OK, Ive removed the DLL from Sys32 folder, and the config file from Windows director. However, MMView is still showing the codec.
GAV
Even though the dll is gone, the registry settings that indicates what codec to use for the HFYU fourcc is still there. I don't know MMView -- does it let you remove the registry entry? If not you can use Filmerit or FilterManager to remove the registry entry.
GAV
Cannot uninstall Nero 9
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2009, 07:31 -
unable to uninstall ffdshow
By WinSpecToR in forum ComputerReplies: 1Last Post: 2nd May 2008, 01:25 -
Can't uninstall codecs
By boonebaker in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2008, 15:09 -
How do you uninstall WMP 10?
By rayden54 in forum Software PlayingReplies: 5Last Post: 8th Jan 2008, 14:59 -
How to uninstall a DVD burner
By DVinci in forum DVD & Blu-ray WritersReplies: 2Last Post: 25th Dec 2007, 22:34
