Hi it shoul be easy but i cant find an easy and automatic way to to do this.
I have more than 100 avi files captured from tv with audio as PCM and I want to convert them to mp3 leaving the video untouched.
I tried virtualdub and it does a great job but the batch mode is not very useful as you have to open every file and give an output name to each, and I have more than 100 files!!!!!.
It would be great some soft were you just tag all files and then convert them..
thanks
Results 1 to 9 of 9
Thread: convert audio in batch mode.....
FulciLives will probably help you make a batch file for just that.
. Private message him or read his posts, http://forum.videohelp.com/search.ph...hor=FulciLives
One way of doing it would probably be to set up a loop in a batchfile, and call the command-line versions of AVI2WAV (to extract the audio stream of an AVI to a WAV file) and LAME (to encode the resulting WAV to MP3) for each file, in order. That wouldn't insert any ID3 tag info, of course, if you were looking for that.
Naturally, I'm sure there's a much more direct way of doing it, probably with mencoder.
See Below. Sorry. Got an error message as I was posting.
Try my AVI_GAIN script, found at
http://forum.videohelp.com/topic314909.html
Use Avi_Gain_regular.bat
It will convert them all to 224kbs LAME processed CBR MP3s, muxed back into the AVI
Thanks for answering
Ai Haibara: I guess thata will get me the mp3 files but i want the avi files..
Soopafresh: IŽll see to that,,, any way to change the bitrate? editing the batch I guess,,
thenks again,,
Yeah, of course. Open Avi_Gain_Regular.bat in notepad. Look for the line that says
lame x-gain.wav -b 224 --cbr -F -m s -h --noreplaygain a-norm.mp3
That's the part I wasn't sure about.Originally Posted by bolador
The original post made it sound somewhat like you were wanting stand-alone MP3s.
I also wasn't sure, offhand, what I could suggest to remux the MP3 back into the AVI (if there were any command-line utilities that would fit into the oddball method I suggested.
Unable to Use Batch mode in MPEG STREAMCLIP for DVD Convert
By winston879 in forum Video ConversionReplies: 0Last Post: 14th Mar 2011, 01:38 -
By nimrodm in forum Video ConversionReplies: 0Last Post: 3rd Jan 2010, 08:27 -
convert to avi in batch mode
By volam1 in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 04:04 -
Video Fade In/Out Batch Mode
By quxote in forum EditingReplies: 11Last Post: 1st Mar 2009, 18:41 -
How to set audio conversion settings in batch mode for VirtualDubMod?
By montango in forum Video ConversionReplies: 2Last Post: 14th Jan 2008, 03:56
