VideoHelp.com Forum
    The one listed in the section doesn't work on my unit. It's below:
    Press "Setup"
    Scroll to "Preference" using the Left/Right arrow key
    Press "138931" and a popup screen will appear
    Use the Up arrow key and select 0 for a region free DVD player
    Done.
    I can get the "Setup" menu to come up, but I don't have a "Preference" tab, just General Setup, Audio Setup, Video Setup, and Exit. There is a field of 6 boxes on the header between Video Setup and Exit, but it when using the remote it just goes right past it.
    Can anyone help?
    You have to be playing a DVD....then hit the STOP button TWICE.....then the SETUP button...this will take you directly to the Setup-Preferences page....then type in the number above(138931) and it should pop-up the window(not really a window just a box with the current region). Use the UP-DOWN arrow key to change the region code to '0' and that should make your DVD player region-free.
    The steps to access the Preferences section are outlined on page 43 of the manual as well.
    hope this helps.
    region-free hack?
    I used the following and it worked fine for me on a recent purchase of a Philips DVP3960
    Power Up the unit with NO Disc in the tray.
    Open the tray
    Press the SETUP Button on the remote control
    Navigate to the PREFERENCES page using the Right Arrow Key
    Press the DOWN ARROW one time to select
    Press the 1 button on your remote control
    Press the 3 button on your remote control
    Press the 8 button on your remote control
    Press the 9 button on your remote control
    The current Region Code Setting will display
    Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
    Press the PLAY Button on the remote control
    Good luck
    Amazing.
    Not only I can change to region 0, also play PAL DVD's on my NTSC TV.
    Very good dvd player.
  1. Philips DVP3960/37
    By thebirdf in forum DVD & Blu-ray Players
    Last Post: 19th Feb 2008, 11:34
  2. Philips DVP3960/37 Divx + Upscaling / $44 ?
    By Dreven7 in forum DVD & Blu-ray Players
    Last Post: 21st Dec 2007, 08:47
  3. Should I get a Philips DVP3960/37 or an RCA DRC279?
    By ntruax in forum DVD & Blu-ray Players
    Last Post: 21st Nov 2007, 09:50
  4. Philips DVP3960 - picture not centered?
    By awp in forum DVD & Blu-ray Players
    Last Post: 24th Jun 2007, 10:18
  5. Philips DVP3960 and audio
    By NES_Master in forum DVD & Blu-ray Players
    Last Post: 24th Jun 2007, 01:57
