VideoHelp.com Forum
    I'm haveing a problem with play back in my DVD player. the screen on the tv appears to have a bad tracking problem (the screen rotates up and down), but it plays fine on the computer no mater how i try to burn it. the movie just wont play right on the DVD player.
    HELP PLEASE!!!!!!!
  2. Member Noahtuck's Avatar
    Is it black and white also ?
    Sound's like you have a PAL video & we are NTSC.
    PC's are not restricted by PAL or NTSC playback as most standalone dvd players and tv's are in the U.S.
    Open it in DVD Decrypter and check the framerate & resolution, or open a VOB in gspot or avicodec & check the framerate, resolution.
    Originally a member since 2001, LONG LIVE TARAN's!!!
  3. Mod Neophyte Super Moderator redwudz's Avatar
    Drop one of the VOBs from the VIDEO_TS folder into Gspot 2.70. Check the framerate. (Frames/s) I suspect 25fps PAL video instead of 29.97 or 23.976fps NTSC. You can probably also check it with some software players. Gspot will also tell you other info about the video.
    And welcome to our forums.
    thank you for the help.
    is there any way to chang from one to the other
    i just hate sitting infront of the computer to watch movies
  5. Member Noahtuck's Avatar
    http://forum.videohelp.com/search.php?mode=results
    Do a search for - convert pal ntsc - see how much effort and learning you want to put into it or.... you can buy a cheapo or expensive "good" dvd player that will convert PAL to NTSC on the fly.
    Usually most people's choice and the easiest.
    If quality is not that big of an issue and you can live without 100% quality comparison you could convert it with nero, ConvertXtoDvd or some other one click wonder but you will lose all the original menu's, chapter points, ect.
    Unless you really want to work on it, spend alot of time & demux the whole dvd, convert each seperate title and menu and reauthor the whole thing.
  1. video play back problems concerning vobsub. Please Help!!
    By fatboy2793 in forum Newbie / General discussions
    Last Post: 27th Jan 2012, 06:03
  2. Problems with play back packard bell dvd player
    By muay in forum Newbie / General discussions
    Last Post: 3rd Nov 2010, 12:08
  3. Dropbox & LG Ally Video play back problems
    By enutz in forum Portable Video
    Last Post: 23rd Aug 2010, 09:45
  4. play back problems
    By heyhi in forum DVD Ripping
    Last Post: 10th Mar 2009, 11:12
  5. DVDs on hard drive for back up and play back on TV
    By yadoc in forum Video Conversion
    Last Post: 2nd May 2008, 20:03
