Results 1 to 11 of 11
    I'm trying to get my computer to automatically shutdown after a certain time. For example, turning it on at 10 pm and shutting down by 4 am automatically. Any ideas?
  2. Member mats.hogberg's Avatar
    Use scheduled tasks, and shutdown? On seems harder to accomplish.
    /Mats
  3. Member CrayonEater's Avatar
    Not all programs deal with a forced shutdown properly, so beware.
    Using Windows Scheduler as somebody else pointed out should handle the shutdown issue. You would issue the command:
    shutdown -s -t 0
    If you want to set your machine to shut down after a certain amount of time after use, run (from DOS command prompt or the Start->Run menu:
    shutdown -s -t [time in seconds]
  4. If what is built-in will do the job, don't use unnecessary software. Task Scheduler and Shutdown.exe will handle this just fine, as Mats suggested.
    There are several ways to automate turning on, most require additional hardware or use a Wake from Hibernation rather than a true Power On. Do you require the automated start-up, or just the shutdown?
  5. AMp winoff is highly flexible and works well for me
    The electronic components of the power part adopted a lot of Rubycons.
    My guess is, yr doing it the hard way. People these days don't turn off their PC, they just put them to sleep then wake/sleep is EZ.
    Why turn it ON at 10PM and then off at 4AM....??????
    Have you tried the on/off button?????????
    Sometimes I just don't understand ?????????
    There may be something I'm missing here.,..
    Turn it on to do whatever...
    Turn it off when your finished......
    What is the problem?????????
    Or leave it on and turn off monitor..
    I just don't understand..........
  8. Check your BIOS settings under power management, most PCs can be set to wake at a preset time.
  9. This program deal with a forced shutdown properly.
    Just choice event and action and click start.
    I just need to shut it down. Sorry for the ambiguity. Anyway, it seems to work now. Thanks
  1. ConvertX2DVD shutdown
    By smalld in forum Newbie / General discussions
    Last Post: 27th Nov 2007, 20:27
  2. Pc shutdown in DVDshrink
    By Scot R in forum DVD Ripping
    Last Post: 15th Feb 2004, 17:09
  3. Automatic shutdown in CCE?
    By Luis Neves in forum Video Conversion
    Last Post: 6th May 2003, 21:57
  4. TMPGEnc shutdown in XP
    By mickle in forum Video Conversion
    Last Post: 5th Jun 2002, 14:08
  5. Flask and shutdown
    By schippy in forum Video Conversion
    Last Post: 21st Oct 2001, 23:27
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
