I want to capture 480p, not 480i, and I was wondering how I could possibly do it? Some of the capture cards out right now just don't give good quality video captures.
Would I be able to capture 480p using the Blackmagic HDMI capture card? I do have the Xbox Elite, so it does have HDMI out. Thanks
Have yet to see any usage reports on the BlackMagic card.
Only other option for 480p SFAIK is the breakout box for the Pinnacle Liquid software, but it is pricey and have not seen any usage reports on that, either.
If I was going to gamble, I guess I would get the BlackMagic card, at least that company seems to have a decent reputation.
Anyone know if the Blackmagic Intensity supports 480p?
Also, can I play my 360 while I record to my computer on another TV screen?
well typically there is lag if you play it off of the screen capture monitor on the computer and would be intolerable. But as long as you split the video out to another tv so you have a direct feed to your capture card and play on another screen you should be able to do it without lag.
Hmmm... I think the Intensity doesn't do 480p. Is there a capture card that can make videos similar to the quality to IGN or somewhere else for game videos?
Visit http://www.cgaming.com for 720p and 480p Game Videos from the Xbox 360 and Wii
xbox 360 capture card?
By blindman96 in forum CapturingReplies: 7Last Post: 26th Mar 2011, 20:56 -
Xbox 360 Capture Card
By Dr Awesome in forum CapturingReplies: 2Last Post: 19th Feb 2010, 05:06 -
What is the highest-quality capture card that I can get for my Xbox 360?
By FinalGypsy in forum CapturingReplies: 8Last Post: 13th Jan 2010, 11:12 -
Using an EASYCAP 2.0 to capture xbox 360
By blazedup427 in forum CapturingReplies: 0Last Post: 14th Mar 2009, 07:40 -
Xbox 360 Capture Help?
By X Kin in forum CapturingReplies: 0Last Post: 14th Sep 2007, 11:43
