I am running vista premium home edition and am a novice when it comes to making dvd's
I can create a project in moviemaker and bring in .jpg and .mpg files to make a movie. I can save the file as a moviemaker file only.
When I try to publish as a movie to a dvd...dvd maker opens and I get an unspecified error and no files have been moved.
I am trying to make a movie that can be played in a dvd player connected to a TV.
Help.
Is there any other software I can get that can convert my moviemaker file into something burnable and compatible?
I do not know for sure, but I would be very much surprised if any other program recognized a Movie Maker project file. If you've spent hours editing this project then perhaps you can render it as a DV avi file (one of the options I recall in movie maker) and then you can proceed to make a DVD the traditional way as described in various guides on this site using more reliable programs.
Thanks for the advice . I found out how to publish the file to my desktop in DV AVI (NTSC) format.
What conversion program would you recommend, there is information overload here and I am not sure what I am doing.
Any encoder supports DV-AVI,I recommend TDA or Ulead VideoStudio.Originally Posted by steve7510
Once you have your edited movie in DV avi format the next two basic steps are:
1. Encode the DV .avi file into a DVD compliant mpeg 2 file
2. Author the DVD with a DVD authoring program
You will have to refer to the guides on this site to fill out the details.
There is a learning curve here if you want to go beyond prepackaged programs like Move Maker (which in your case isn't an option since it has failed to work).
Microsoft Vista Movie Maker gives best DVD quality
By quickfamily in forum Newbie / General discussionsReplies: 6Last Post: 26th Jan 2009, 15:06 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53 -
Vista Movie maker
By pgarg2000 in forum Newbie / General discussionsReplies: 8Last Post: 3rd Aug 2008, 10:08 -
vista dvd maker
By benny28 in forum Authoring (DVD)Replies: 8Last Post: 16th Apr 2008, 16:15 -
Vista Windows Dvd Maker
By tvlreject in forum Authoring (VCD/SVCD)Replies: 1Last Post: 23rd Jul 2007, 19:48
