Hi all:
I did many times convertion with convertxtodvd and had no problems with subs.
Now after a format of my HD every convertion I tried the subs are not showing !!
Am I missing something ??
If I remember right Convertxtodvd dont need any external codecs to add subs.
Any ideas ??
tks.hilario.
No, you don't need any codecs to add switchable subtitles using convertxtodvd.
are you using same version of converxtodvd as before?
what is your video source? what is your video subtitle source?
I assume you have tried to manually enable the subtitle when you play it?
Hi Baldrick:
Yes using same version as before, and tried manually enable subs.
I can see that subs are added on the convertion report.
I really dont know where is the problem !!
Even stranger is that same movies converted with Winavi always show subs !!!
This is really strange.
I'm playing the IFO files generated with KmPlayer.Tried all possible solution, but no way.
Will go on trying.
Will be back if I found the solution.
tks Baldrick
subtitles and convertxtodvd
By babeflover in forum SubtitleReplies: 4Last Post: 30th Nov 2010, 21:24 -
Subtitles and ConvertXtoDVD 3
By sissyfoot in forum SubtitleReplies: 1Last Post: 10th Nov 2009, 22:14 -
Heb Subtitles in ConvertxtoDVD
By eliqush in forum SubtitleReplies: 0Last Post: 15th Jul 2009, 02:10 -
Subtitles in ConvertxToDVD
By lanooz in forum Authoring (DVD)Replies: 0Last Post: 4th Nov 2008, 09:07 -
Subtitles distorted with convertxtodvd
By MasterRoshi in forum Video ConversionReplies: 13Last Post: 19th Jan 2008, 22:37
Statistics
Newest guides
Latest tool updates
New media comments
