VideoHelp.com Forum
    I have two identical video clips.
    With one exception one video clip has words on it.
    Is there away in Adobe Premiere to edit out anything that is in duplicate i.e. remove everything except the words. And then lay that video track (words only) over a different clip to have the words on that clip?
    Look at the Difference Mask (it might be called something similar but different). Otherwise just create you own title - which is probably easier.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Thanks for the help
    I will try it
    As far as making my own title, its not just the words its the movement and design they make that makes it unique. I dont quite have that level of skills to do that yet.
    Post a screenshot - it might prompt some new ideas
  1. Remove duplicate text from SRTs
    By cal_tony in forum Subtitle
    Last Post: 9th Feb 2012, 21:49
  2. Remove Duplicate Frames
    By robindean in forum Video Conversion
    Last Post: 11th Mar 2010, 15:30
  3. remove audio part of mpg
    By zmartha in forum Audio
    Last Post: 19th Oct 2009, 18:51
  4. Do youtube remove 'duplicate' submitted videos?
    By Entry in forum Newbie / General discussions
    Last Post: 10th Jun 2009, 20:21
  5. Replies: 15
    Last Post: 3rd Apr 2009, 08:36
