so theres no way to take 2 cue/bin movie files and mount them to a dvd instead of 2 cds? I would have to convert them to mpegs2?
Please do not hijack topics. Start a new thread for a new question.
I've split this off as a new thread.
No, you can't add 2 cue/bin to one disk.
But if you mount the 2 cue/bins (provided they are images of Video DVD) with daemon tools, they can be easily merged to one Video DVD with DVDShrink in reauthor mode (no menu), or with DVDRemake (incl full menues https://www.videohelp.com/guides/simplistic-guide-to-join-two-or-more-disc-dvd-flipper-...enus-id953#953) or with TDA (custom menu). The mounted images can be treated as if they would be physical disks in your reader.
/Mats -
...but can it take the input from 2 BINs, and put them on one disk? And what's in those cue/bin? Until we know, all suggestions are only guessings.
/Mats -
As the OP mentions that the bins are on 2 CD's i think we can safely assume they are not dvd files (ie they're not TS folders) my guess would be that they are vcd (or svcd) files which means that the audio will need to be resampled to 48khz (it will currently be 44.1khz) svcd2dvd will do this as will many other applications (or you could do it manually by demuxing >> resampling >> (re)muxing).
Best option it to first mount the cue/bins with daemon tools and extract the mpegs or you could use vcdgear to rip the mpegs from the cue/bins .... once you have both mpegs on your hdd you can use (a) suitable application(s) to author a dvd containing both parts as one complete movie -
Originally Posted by motleycool
Use the SVCD2DVD as suggested by others. (There's a free version available.) This gives you MPEG1 files with audio resampled to make them DVD compliant. This is pretty fast and the video isn't degraded by conversion.
You can join the two MPEG1s if you have a MPEG editor, but otherwise your DVD authoring app should let you make them run one with perhaps a brief pause between parts.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
