VideoHelp.com Forum
    Heya,
    I am using GUIforDVDAuthor, but am open to recommendations if another program can do it. What I want to do is when a button has focus, if I press the right/left/up/or down arrows I can control which is the next button to get focus depending on direction. Any way to do this?
    Thanks,
    Kevin
  2. Member blutach's Avatar
    Easiest is PgcEdit's menu editor. Simply set the adjacent buttons with the slider.
    Regards
    Les
    Yeah, the reason I'm asking is I've seen a commercial dvd that has a hidden button that can only be accessed by pressing the left arrow, but not the right. I am hoping to do the same thing. Thanks for the info on PgcEdit I hope it does that.
    Thanks for your help.
    -Kevin
    DVD Lab Pro can do this. Just turn off the auto function and assign button order manually.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  5. Member GeorgeW's Avatar
    I used DVDLab Pro to do that recently. I had it count the number of times the right-arrow was pressed, and after a certain number of times, a new menu appeared.
    But as blutach mentioned, easiest method on an already-authored DVD is something like PGCedit (or even DVDRemake or MenuEdit).
    Regards,
    George
  6. Member Alex_ander's Avatar
    Originally Posted by GeorgeW
    ...or even DVDRemake ...
    ...right-click on button =>'edit button' => type adjacent button numbers.
    PgcEdit does allow you to add buttons to a menu. If such buttons don't overlap an ordinary button already present in the menu, they would not be visible, even when they have the focus.
  8. You can do it in GfD too, if you edit the control file (author.xml if dvdauthor is used as authoring engine, or muxman.mxp in coas of muxman). Just set a tag in the default project settings at 'Edit author.xml file before DVD creation process'.
  1. Circle or arrow to point out highlighted player
    By adrian1472 in forum Editing
    Last Post: 10th Feb 2012, 23:45
  2. Replies: 0
    Last Post: 10th Feb 2012, 21:49
  3. Replies: 3
    Last Post: 24th Oct 2009, 22:54
  4. Replies: 4
    Last Post: 26th Jul 2009, 01:06
  5. Replies: 4
    Last Post: 11th Sep 2007, 13:46
