VideoHelp.com Forum
  1. Hello,
    I'm interested in buying a USB memory stick of 4/8GB.
    I'm mainly aiming for fast data transer rate: 24MB/s Read (And Higher) 18MB/s, Write (And Higher)
    I want to be able to copy fast onto the USB stick, all those DivX/Xvid anime and games I download at my work pc.
    This Kingston stick looks good, but it's only 4Gigs:
    http://www.superwarehouse.com/Kingst...4GB/ps/1489284
    http://www.ec.kingston.com/ecom/conf...TII+M/4GB&id=1
    Or this 8Gig stick, but it’s slow:
    Read 9-10 MByte/s, Write 2 MByte/s.
    http://www.e-shop.gr/show_per.phtml?id=PER.554483
    So, which specific stick do you guys recommend?
    http://www.patriotmemory.org/product...Drives&catid=8
    I have 3 , 2 converted over to bootable .
  3. Member MJA's Avatar
    check the OCZ RALLY High Performance Dual Channel Flash Drives
    http://www.newegg.com/Product/Produc...ubCategory=522
    or
    SanDisk 4GB Cruzer Freedom $31.99 free shipping
    http://www.buy.com/prod/sandisk-4gb-...tml?adid=17662
  4. I've decided to go with this:
    CORSAIR Flash Voyager GT 8GB Flash Drive
    Mainly for its great speed:
    Read speed: 34MB/s
    Write speed: 27MB/s
    http://www.newegg.com/Product/Produc...82E16820233054
    The 16GB version looks cool, but it’s too slow Especially write speed:
    Read speed: 22MB/s
    Write speed: 7MB/s
    However, after reading through some reviews regarding the Corsair rubber USB sticks, I noticed quite a few people claming that the cap is too loose, it can easily fall off and get lost. Once it's gone, the USB connector can brake easily:
    http://www.newegg.com/Product/Produc...82E16820233009
    http://www.newegg.com/Product/Produc...82E16820233053
    http://www.newegg.com/Product/Produc...82E16820233007
    The rubber casing is easily removable and runs risk of exposing inside of drive.
    http://www.newegg.com/Product/Produc...82E16820233042
    So, is that's true?
    If that's the case I might go for a simpler Kingston stick out of hard plastic which I've tried and are great.
    Any thoughts will be greatly appreciated!
    Thanks in advance
  5. Somehow the prospect of losing those lame Corsair Caps did go too well and the 16Gigs just weren’t enough for my needs, so I bought one of these cool External WD 250Gig USB drives!
    http://www.newegg.com/Product/Produc...82E16822136139
    It’s very light, about as much as a regular cell phone.
    Very fast (I’ve achieved 33MB/s transfer rate (Write/Read)
    Very quite (I don’t even notice it when it’s working)
    And it’s very sleek in design.
    The coolest thing is that you don’t even need extra power adapters, its powered straight from the USB port and yeah you just can’t beat 250Gigs!
    Me Happy!
    However, I’m not sure if it will work well (if not at all) on the older USB 1.1 ports, will it get enough power?
  1. Replies: 6
    Last Post: 26th Sep 2008, 23:07
  2. question about fake USB memory stick
    By jimdagys in forum Computer
    Last Post: 30th Mar 2008, 23:58
  3. Replies: 2
    Last Post: 7th Oct 2007, 20:38
  4. Can you burn an ISO image to a USB memory stick?
    By haymes in forum Portable Video
    Last Post: 11th Jun 2007, 07:47
