VideoHelp.com Forum
Results 1 to 9 of 9
    Hi, I am new and not sure that my post is in good place. Anyway, I have Samsung DVD-R135 made in China and I am in Canada. Does anybody can help me how to play DVD from Europe on this player?
    stasioau
  2. Member mats.hogberg's Avatar
    Hi, and welcome to VideoHelp!
    Googling for "samsung dvd-r135 hack" gave 318 hits. Tried any of those suggestions?
    /Mats
  3. Member hech54's Avatar
    Canada is NTSC
    Europe is PAL
    A region code hack alone may not solve the PAL - NTSC problem.
    Well I check Google yesterday and today. There is nothing new but only old one=<menu,29334,9,menu,menu> Numbers just change channels. Regards, stasioau
  5. Member Krispy Kritter's Avatar
    Funny how everyones wants a region free player after buying one that doensn't support region free.
    Google is your Friend
  6. Member mats.hogberg's Avatar
    Well, it could be, not all are as knowledgeable as you and me, and simply don't know or care about region codes until faced with a disk that refuses to play?
    Anyho - The solution (if the player isn't hackable) is simply to back it up to DVD-R, as all(?) rippers remove the region code protection by default.
    /Mats
    I know, I know, I should check DVD recorder before I buy, if can play my Europe disks. I have been told: of course you can play all DVD on this recorder.
    Mats, please give little more explanation what you mean: “The solution (if the player isn't hackable) is simply to back it up to DVD-R, as all(?) rippers remove the region code protection by default”. Go back to store? Shop?
    Anyway, thanks so much all of you.
    stasioau
  8. Member mats.hogberg's Avatar
    I mean: Make a backup copy of your wrong region code disk. The backup will be region free, so should play if it's not also is using a TV system your player can't handle. (Many Region 2 disks are PAL, while Canada use NTSC, it seems - not many NTSC players handle PAL disks.)
    /Mats
    Thanks Mats, I will try
    Stasioau
  1. Hack code for multiregion DVD Samsung MAX DX75???
    By ltcdrcharisma in forum DVD & Blu-ray Players
    Last Post: 11th Mar 2011, 16:46
  2. Region Free Hack Code for Samsung R3 DVD Player P255K
    By Scoop in forum Newbie / General discussions
    Last Post: 9th Mar 2011, 00:01
  3. Need some Feedback: Philips DVDR3475/37 and Samsung DVD-R135
    By BrokenOne in forum DVD & Blu-ray Recorders
    Last Post: 16th Dec 2007, 23:58
  4. Looking for hack code for Samsung DVD-R150
    By veronokwok in forum DVD & Blu-ray Recorders
    Last Post: 9th Jun 2007, 01:20
  5. Looking for hack code for Samsung DVD-R150
    By veronokwok in forum DVD & Blu-ray Players
    Last Post: 9th Jun 2007, 00:04
