If I am burning 12 DivX files (TV episodes) to a DVD-R, what is the difference between using the ISO or UDF options? Will one yield better results or compatibility than the other? I am using Nero 6.6.0.1.
I have been researching this but the explanations I have read are confusing, is there a straight forward answer to this? My DivX files are in the neighborhood of approx 350MB each. I have read that UDF is only for handling files 2GB and larger, if this is the case then ISO would be my only option, am I understanding this correctly?
Also are ISO & UDF the only options to choose from when burning multiple DivX files to a DVD-R for play on a standalone player?
I finally perfected my ripping process, now I am attempting to optimize my burning process.
Thanks for reading...
Mike
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind...
DVDs (and any newer optical disc types) are all supposed to be built with at least UDF as a base Filesystem. This doesn't have to rule out combination (aka "Bridge") filesystems (1 or more added to UDF, such as ISO9660--with or without Joliet-- or HFS/HFS+ or Rockridge, etc).
That being said, there are lots of examples of hardware and software players that bend these rules and still seem to work OK.
I'd start out trying a UDF (v1.02 for compatibility with DVD-Video spec)+ISO9660 Bridge disc (since your files are <2GB each), and see where that gets you (use a Rewritable so you won't waste a disc). Then try UDF only, then ISO9660 only.
If you write the AVIs as data (not reencoding and authoring as Video DVD), std ISO is what to use.
/Mats
UDF or ISO? Use whichever you Divx/DVD player plays. ISO is more commonly used these days. But some older Divx/DVD players only play UDF.
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 17:18 -
File structure of UDF-ISO image files
By Waly in forum ProgrammingReplies: 5Last Post: 21st Oct 2010, 09:44 -
How can I salvage ISO with invalid UDF File Syetem?
By V Bot in forum Video ConversionReplies: 1Last Post: 10th Jan 2010, 20:37 -
Burning with UDF
By gooberguy in forum Authoring (Blu-ray)Replies: 9Last Post: 18th Jul 2009, 17:01 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01
Statistics
Newest guides
Latest tool updates
New media comments
