VideoHelp.com Forum
  1. Member daamon's Avatar
    Hi all,
    I have recently bought an 8Gb USB key / flash drive. I want to be able to produce a home-made DVD file structure (i.e. VIDEO_TS folder with VOBs, IFOs & BUPs) and play them back from the USB key - but using an application that's on that key.
    That is, I don't want to have to rely on a software DVD player on a PC, or have to install one on a PC. Freeware to put on the USB key is preferred, funnily enough...
    Any suggestions?
    Cheers.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  2. Member buttzilla's Avatar
    I believe Media Player Classic can do what you want.
  3. The root of all evil träskmannen's Avatar
    You can get a portable version of VLC here.
    In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
  4. Member daamon's Avatar
    Thanks guys. Will either or both have full DVD playback functionality - i.e. first play item, menus, highlighted buttons, chapters etc.?
    I essentially want a portable version of something like PowerDVD or WinDVD - does that exist?
    I can't try either because I don't have access to my home PC for a few days (and work is locked down), and I can't see anything on their write up that answers my question.
    Thanks.
    Carpe diem.
  5. The root of all evil träskmannen's Avatar
    Both support menus, highlighted buttons, chapters and subtitles - I wouldn't know about first play item since I am at work and I have nothing here to test with. (I don't have time enough to create anything right now either).
    Just drag and drop the VIDEO_TS folder in the application you choose.
    I had to use the mouse to navigate the menu in MediaPlayerClassic while VLC supported both arrow keys and mouse.
    You can check for other portable players here, maybe you can find something else that suits your need better.
  6. Member daamon's Avatar
    @ träskmannen: Excellent! Thank you - I'll check 'em out.
    Carpe diem.
  7. Member daamon's Avatar
    Absolutley perfect for my needs - spot on!!! Thank you.
    Carpe diem.
  1. Converting VOBs to Play on my Xbox 360
    By Wumpscut in forum Media Center PC / MediaCenters
    Last Post: 26th Apr 2011, 20:37
  2. LG LH-T751TB USB key issue?
    By the shutdown man in forum DVD & Blu-ray Players
    Last Post: 3rd Jun 2009, 10:47
  3. Philips DVP 5960, compatible USB Key List
    By phunkyfish in forum DVD & Blu-ray Players
    Last Post: 30th Sep 2008, 10:18
  4. Replies: 4
    Last Post: 3rd Feb 2008, 13:27
  5. TDVD08 and 4GB USB Key problem
    By hemyd in forum DVD & Blu-ray Players
    Last Post: 21st Aug 2007, 11:53
