VideoHelp.com Forum
  1. I'm interested in converting some videos to wmv because it's the only mutual format for both the Zen Vision M and the Zune. I'm the owner of a Zen, and i know two Zune owners.
    From my understanding, the Zen is alot pickier about wmv videos. not every .wmv video i get from the internet works on my zen, regardless of whether the resolution is supported or not. While i'm on the subject, why does it max out at a measily 320x240? I can play divx/xvid videos at 720x480, so why not the same for wmv?
    Anyway, back to the point. If i use Windows Media Encoder, (or another wmv converter?), what specifications would i have to apply to the encoding to make it mutually compatible with both players? I can't seem to be able to find any info on this. Perhaps i'm not looking hard enough... i dunno. Any help?
    asdf
    Well,
    I currently have both of them at my home as I'm testing which I actually want.
    I got the Zune first and converted a bunch of xvid's to WMV since the Zune requires that. I then got the Vision W and tried to copy those same files over...NO GO.
    Problem was that the Vision requires WMV9, while the Zune can take 9,8, or 7 (i believe). I converted to 8 since it was faster though.
    So, with WME you'd at least make sure you are going to WMV9.
    It can max out at a total of about 780kb/s max bit rate because of the Zune's limitations. So I use 700kb/s for video and 64kb/s for audio (seems low, but sounds just fine for videos).
    Zune won't take anything that is VBR, so it needs to be CBR for video.
    So, in short: WMV9, max 780kb/s , CBR video, and as you stated max 320x240 resolution, that should get you started.
  3. Originally Posted by churchie04
    Well,
    I tried using Windows Media Encoder to convert some stuff to wmv9, etc and it still didn't work in my zen. I could use the Creative video encoder, which is really not a very good encoder, to convert stuff to wmv. but i don't know if the files it produces are zune-compatible, since i havent had a chance to give said files to any zune-owning friends.
    Also, i can't do much with WME at the moment, because it has vista compatibility issues. A MICROSOFT PROGRAM doesn't work properly in Vista. ugh.... I haven't run into very many programs that didnt work right. This is probably the second. But i just can't get over the fact that it's a MS program that doesn't work.
    If you can find out what program works very well, and produces mutually compatible files, please let me know
    asdf
    From the official Zune website (http://www.zune.net/en-us/support/ho...enjoyvideo.htm)
    The Zune device supports the following video codec:
    * Windows Media Video: up to 320x240, 1.692 Mbps, Main profile, files with extension .wmv
    have you tried gspot on a file that works, or media info, to get the exact specs..
    then try duplicating those settings, you might try super, it can do a large number of formats, and lets you set the video and audio bit rates and Frame rates
    FPS
  6. Member RogerTango's Avatar
    I am encoding my WMV with WM9 audio and video, both CBR... Video at 300kbps, video is very good quality. I am using AviSynth to feed to Nic's WMEnc, results are VERY GOOD.
    Using this, I would suspect that both the Zen and Zume would play it fine. I however only have the Zen (and love it!!).
    HTH,
    RogerTango
  7. I've found that the creative video converter seems to create wmv files that are cross compatible.
    asdf
  1. converting for Zen
    By stigslim in forum Portable Video
    Last Post: 10th Mar 2009, 05:06
  2. Adding cover art to WMV to be transfered to the Zune
    By MC Rodimus in forum Portable Video
    Last Post: 2nd Mar 2009, 23:43
  3. DVD Shrink + ??? = Zune-compatible .MP4/.WMV?
    By BlueOlive in forum Newbie / General discussions
    Last Post: 23rd Sep 2008, 17:25
  4. Replies: 4
    Last Post: 31st Dec 2007, 20:45
