I am trying to not use flip4mac as when I import the wmv or QT movies into iMovie as when I do I get the Flip4Mac Trial water mark on the video.
I am trying to convert both wmv or QT files to DV so I can import them into iMovie to create a movie and ultimately burn a DVD with iDVD. I have an Intel Mac with OS 10.4.x When I try to create the file using FFmpeg the process takes only a few seconds and the created file is zero in size and is unreadable. This happens for both file types. I get the following message in the terminal window "Codec type mismatch for mapping #0.0 -> #0.0"
Tried Mpeg Streamclip?
When I use Mpeg Streamclip the resultant DV has the flip4mac watermark.
I'll beat Case on this one, as he usually answers this,
but you need to check "invert mapping" in ffmpegx
in the audio tab. Unless it's be encoded with WM 11,
it should process the file properly then."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
When I do that it just fails with the error in the terminal window of:
Unsupported codec (id=0) for input stream #0.0
or
Could not write header for output file #0 (incorrect codec parameters ?)
unsupported codec--if you play in VLC, and perform
a Information command, what does it say about the stream?
or, can you check the information box in QT/F4M and
what does it say...?"Everyone has to learn, so that they can one day teach."
Urban Mac User
Free editing sotware that's better than iMovie and easy to use?
By Karel Bata in forum MacReplies: 15Last Post: 9th Feb 2010, 15:51 -
Preparing Video on a PC for editing on a Mac with iMovie ?
By beammeup in forum MacReplies: 5Last Post: 13th May 2009, 19:57 -
Newbie needs help - wmv to DVD and iMovie
By Jeff555 in forum MacReplies: 7Last Post: 16th Mar 2009, 15:27 -
iMovie files won't reduce in size after editing
By SyracuseMug in forum MacReplies: 1Last Post: 19th Jan 2009, 12:06 -
MPEG2 to MPEG4 for iMovie editing on a MAC
By AAL333 in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2007, 23:01
