Hi,
I want to compare two subtitles files and don't find the way to open them at the same time in Subtitle Workhop. Is there a way to do that, to have both of them in the same window of the program? I mean in some split window, one above and the other below, or something like that.
Thanks in advance
Yes, there is a way,
Do the following:
Open the first subtitle in SW.
Then use 3 shortcuts, one after other:
CTRL+U
SHIFT+CTRL+W
SHIFT+CTRL+X
After that 3. shortcut, a window will pop-up and you have to open the second subtitle.
Now you should have both subtitles in in a same window in a split mode, side-by-side.
P.S. Those shortcuts belong to a Translation mode under Edit. If your time codes and number of subtitles are the same in both subtitles, you should have a nice comparison of both texts.
Amazing!
Thanks a lot! That's what I was looking for.
I tried it and works perfectly, the only thing is I don't know how to open again Subtitle workshop in a normal way. I mean, after trying that I closed the program, I opened it again and it seems to be with the same configuration, translation way. Probably it needs some other shortcut to load just one subtitle in its habitual way
I edit: I found the way: unticking the translator mode
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 03:09 -
Convert pac subtitle to something that I can open in Subtitle workshop
By Tiger_1982 in forum SubtitleReplies: 10Last Post: 19th Apr 2011, 15:37 -
how to open chinese subtitle in subtitle workshop
By pcb in forum SubtitleReplies: 2Last Post: 28th Nov 2010, 16:03 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
Subtitle Workshop loses sync if time controls are used?
By Antaeus Feldspar in forum SubtitleReplies: 7Last Post: 23rd Jan 2008, 23:26
Statistics
Newest guides
Latest tool updates
New media comments
