VideoHelp.com Forum
    hi to you all,
    juat wanted to say a BIG THANK YOU to Classfour, you solved the problem.
    Once i bought the component cables and then put them into the back of the DVDPlayer, i could once again select the "HOME MENU" on the dvd player and see the menu come up again.
    Does anyone know if this is a bug with the software or not?
    To view the menu without component cables, i had to reset it back to interlaced and then i could select and see the "HOME MENU" on the lcd tv screen with the standar rca cables, red, white and yellow.
    But i will leave the component cables in because, apparently get better quality pictures when watching DVD's. Is this also for the TV or just watching DVD's? Just curious.
    thanks again
    cheers kev[/b]
  2. Mod Neophyte Super Moderator redwudz's Avatar
    kbm, in the future, just add to your existing thread instead of starting a new one about the same topic.
    Moderator redwudz
    sorry about that
    kev
  1. Toshiba SD-V295KU - locked tray - SOLVED!
    By Stiiv in forum DVD & Blu-ray Players
    Last Post: 23rd Dec 2010, 00:52
  2. Pioneer DV-220KV-K DVD Multi Region Player is totally locked!!
    By Vandor in forum DVD & Blu-ray Players
    Last Post: 16th Feb 2010, 08:09
  3. Replies: 9
    Last Post: 4th Jun 2008, 08:30
  4. I am confused about the DTS playing capability of my Pioneer DV-393-S...
    By oleglelchuk in forum DVD & Blu-ray Players
    Last Post: 18th Apr 2008, 21:34
  5. Replies: 7
    Last Post: 27th May 2007, 00:39
