VideoHelp.com Forum
Results 1 to 10 of 10
Thread: Convert .m2ts?
    I got a new HD camera (Panasonic HDC-SD1) and it saves files in either .MTS or .m2ts format, and I need to convert these to something so that I can edit them, but so far I can't find a simple way to do it. No program will even read the files.
    It's not so much the converting as it is the capturing..
    There are a few programs available now that will capture HD..
    I believe Pinnacle Studio 11 does so. There are some others..
    Your ahead of the curve , I'm afraid..
    Most people with HD shoot in SD "for the moment"...
    Don't try to "convert" an HD video...It will look like CRAP....
    Besides, you need a super=duper computer for HD........
    I assume you do????
  3. BuskerAlley.com zoobie's Avatar
    I think you'll have to use an editor that handles AVCHD
    They're shooting in HD but use the cam to downconvert for the moment until upgrading to the super-duper computer
    Check out the thread below for more info
    http://forum.videohelp.com/topic329901.html
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
    Hm, seems like a lot of work. I think ill just take this back and get a HD camera that records to minidv or something where I don't have to convert one file from another.
  5. Member Soopafresh's Avatar
    Canon HV20 is pretty decent and outputs plain ol' Mpeg2.
    A clip from Solomon Chase, a videographer who used the HV20 for these shots.
    vts_01_1.mpg
    Awesome. I guess I'll take this back and get that tomorrow then.
  7. Member Soopafresh's Avatar
    With any of the newer cameras, you'll always want to be careful about not panning too fast while shooting. Keeping the camera steady will make a big difference. Otherwise, you'll have to keep an airsickness bag nearby whenever you edit the footage.
    Thanks for the tip, as I had no idea.
    Is there a HardDrive based highdef camera that saves to a useable format?
    Damn, thats $600 more than I spent (at bestbuy).. but I kind of want to get it now.
  1. Why convert m2ts to mkv ?
    By dude905 in forum Video Conversion
    Last Post: 31st Jul 2011, 09:17
  2. how to convert a m2ts to dvd
    By splinter3217 in forum Video Conversion
    Last Post: 18th May 2011, 18:04
  3. how do you convert m2ts
    By Onceler2 in forum Video Conversion
    Last Post: 8th Dec 2009, 05:12
  4. convert m2ts files
    By dvd1304 in forum Newbie / General discussions
    Last Post: 26th Sep 2009, 08:10
  5. M2TS files - can I convert them ?
    By Bansaw in forum Video Conversion
    Last Post: 10th Dec 2008, 10:32
