    I have a Pentax Optio camera which I use for taking still images.
    I also have an underwater case for it, and have recently used it to capture video underwater. The only problem is that it captures at 30fps (320x240), and I would like to combine the video footage with video shot above water on a normal camcorder using the PAL format (25fps).
    Is there any way to change the recorded frame rate of videos on still cameras?
    Perhaps there is a firmware update which can do this?
    There is nothing obvious in the manual / standard menu settings.
    I would prefer to capture at 25fps rather than convert the 30fps to 25fps whilst editing.
    Thanks for any help
  2. Member Alex_ander's Avatar
    I have 25/30 selectable on Sony, try to search for it in the manual, it can be hidden in setup menu.
    I haven't seen any still camera with 25fps, it's usually 15fps or 30fps....so it must be complex to change it...or ?
    Where is that menu on Sony cameras?
    My friend has a Sony, so at least that would work if I used his camera.
    Are then any standard ways of getting to a hidden setup menu?
  5. Member Alex_ander's Avatar
    Here's the manual for my camera and I only see 'video out' PAL/NTSC setting on p.53. It is possible that the same captured frames are outputted one of the 2 ways as MPEG1.
    http://www.henrys.com/manuals/sony/S...5%20manual.pdf
    The manual is from this big collection:
    A Pentax Optio manual that came to my view mentioned just 15/30 modes.
    Alex_ander, are you talking about the outputting of images to TV, or the capturing of video files.
    My understanding is that most cameras will allow you to specify PAL (25fps) or NTSC (29.97fps) output for viewing still images on your TV. This is not what I am interested in.
    What I am interested in is: when you capture a video file, what frame rate does it get capture at, and like Baldrick has said, I have only seen cameras that do 30/15fps.
    I will take a look at the manual link you sent.
  1. panasonic lx3 stills camera movie mode
    By charlietoosey in forum Mac
    Last Post: 18th Dec 2008, 06:46
  2. internal camera, Vista OS, how do I record?
    By danindel in forum Newbie / General discussions
    Last Post: 8th Oct 2007, 13:51
  3. How do you record STRAIGHT to the camera?
    By Wilstysabsinthe in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 31st Dec 2006, 04:53
  4. Record from a camera and Stream at the same time
    By olobay in forum Media Center PC / MediaCenters
    Last Post: 29th May 2006, 12:45
  5. Record on DVD camera and edit
    By wolfwood87 in forum Mac
    Last Post: 23rd Nov 2004, 01:06
About   Advertise   Forum   RSS Feeds   Statistics   Tools
