VideoHelp.com Forum
    ok, i have this cam here
    High Definition Everio Hard Disk Camcorder
    GZ-HD7
    more info - http://www.jvc-australia.com/JVC/cli...D=4&prodID=270
    now, i can backup the files to my PC, but they are in .TOD format
    what the hell is .TOD???? ive never seen it b4
    i can go to edit the videos on my PC, which copies them to my PC as mpeg files, and they are roughly the same size, so im guessing wen it puts it to my PC in mpeg format, it doesnt lose quality???
    any help will be appreciated
  2. Member Krispy Kritter's Avatar
    It's most likely a proprietary format used by the camcorder. And there is most likely a loss of quality after conversion to mpeg, especially if the files are the same size. But that is to be expected, especially since the DVD format doesn't support HD. All you really need now is a DVD authoring program to ensure the files meet dvd specs and get them in the proper format.
    Take a look in the HOW TO - Author section.
    Google is your Friend
  3. Member edDV's Avatar
    This is a special case camcorder. Use the software that shipped with it.
    http://www.camcorderinfo.com/content...iew/Format.htm
    It is intended for Blu-Ray authoring.
    so, basically, i need to buy a blue ray burner?
  5. Member edDV's Avatar
    I haven't used their software but it probably transfers and may allow conversion to normal MPeg2. Id call JVC support. Little is known about this camcorder.
    According to JVC, the top format is the result of copyright issues.. Which means that it actually is an mpg-file.. just rename it and it will work just fine... Yeah
  1. Try to burn a video from iTunes
    By NewtoBurning in forum Newbie / General discussions
    Last Post: 24th May 2010, 07:18
  2. Cant burn Video TS in Toast
    By 3lutz3toe in forum Mac
    Last Post: 11th Sep 2009, 16:31
  3. Can't burn video TS with nero
    By anfield7 in forum Newbie / General discussions
    Last Post: 2nd Dec 2008, 02:19
  4. How much video can I burn on a DVD 5
    By Sikander in forum Authoring (DVD)
    Last Post: 15th Mar 2008, 10:30
