Is there a freeware program that you can suggest? I want to trim the videos I captured from my HD camcorder using Capdvhs. Windows Movie Maker will do it but there is no option to retain the original MPEG2 format. Thanks.
Results 1 to 9 of 9
Without encoding is the tough part, especially with free apps. Plunk down $50 and get Videoredo . You won't regret it. That's one of the few commercials apps I'd ever recommend.
Codecpage - yeah, mpg2cut2 is a great app, but it doesn't work well with transport streams.
I don't know about HD video but for regular mpeg2 I don't think you can beat Cuttermaran in the free department. You'll need a demultiplexer, bbdmux is a good one. I wrote a small batch file and you are welcome to it, you can just drop files one at a time on it and let it go, the resulting files can be loaded into Cuttermaran and cut as you please. Read the documentation for informaton about cutting mpegs with out re-encoding.
Thanks, guys.
I'll give mpg2cut2 a try and see what happens. My other option is to re-capture from the tape. But my lemon Sony HC-3 broke for the third time. I might as well wait for it to be fixed AGAIN.
What happened was, I captured about 25 minutes of HD-MPEG2. Just enough to fill the DVD. Problem is halfway, the PC's hard drive became busy (this problem is discussed in another thread). I did not realize that it affected the capture.
I already re-captured that problem part thinking that I can cut the original capture and then record them on DVD as two files. I can live with that. Anyway, the PC's hard drive could not behave well in full 25 minutes. But my Sony does not like me.
MpegStreamClip - save to TS. It has a good preview and will cut on "I" frames without re-encoding.
There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
cant trim/cut mpg in QT-pro
By Kevlin in forum MacReplies: 3Last Post: 17th Aug 2008, 14:25 -
How to trim/cut in the Magix Movie Pro 2004
By kool in forum EditingReplies: 2Last Post: 27th May 2006, 13:47 -
Need To Trim Edges of mpeg2 Captures
By R55B in forum CapturingReplies: 2Last Post: 6th Mar 2006, 20:01 -
Editor to perform Multiple cut/trim in a single video clips
By NetRodent in forum EditingReplies: 3Last Post: 19th Mar 2004, 08:32 -
Will these upgrade help trim down TMPGenc encoding time?
By brycastillo in forum Video ConversionReplies: 17Last Post: 11th Jan 2003, 10:59
