i've recently bought a panasonic dmr-rx85 recorder and i'm finding all the dvds i burn from its hard drive have timecode breaks.
after burning a disc on the panasonic i use mpeg streamclip on my powerbook to open the vob files. i get the fix timecodes message & do that & find that there are breaks every 15-25 seconds of the file.
after demuxing the files i import them to dvd studio pro (to author with a menu)
and they invariably have audio dropouts at about the same frequency (maybe there are image dropouts too, but this is not so apparent when viewing).
is there anything i can do to fix these problems ?
thanks,
mark
Results 1 to 9 of 9
Panasonic uses a faulty AC3 encoding method. You need to import the file into something like Womble MPEG Video Wizard (I know, it's Windows, do it anyway), chop off at least 1 frame somewhere, and then export the stream using MP2 audio. Womble is the only software I know of (VideoReDo might do it too, not tested) that will fix the mess.
Yet another reason Panasonic recorders are big pieces of crap.
This problem is annoying.
There is nothing on Mac that works for this that I have seen. You will have to use a Windows machine for this task, and I suggest using Womble MVW.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
I have tested quite a large number of recorders and have clips saved from all of them. I downloaded Mpeg-streamclip for Windows and tried clips from a JVC M10S, an RCA 8030N, and a Panasonic DMR-EH55S. Here are the results,
JVC M10S
RCA 8030N
Panasonic DMR-EH55S
The RCA records in +VR mode. Mpeg-streamclip balked at opening it but an option popped up for "open anyway" and it did.
thanks for this info lordsmurf, though it's tough news for me to take. i bought the panasonic because it had consistently good reviews, and now you're telling me i need to buy a windows PC to fix the problems with panasonic's software !
does anyone have any experience of fixing this encoding problem on a mac ?
and if panasonic's are big pieces of crap, which machine should i have bought ? (i'm in the uk).
thanks,
mark
The problem is the software not the recorders.
without good software, the recorder is useless !
m
Yes, I was hoping Mpeg-streamclip would be something useful until I tried it with vob's from several recorders. They all gave the time code error. I actually tested vob's from two different JVC's, one RCA, one Panasonic, and one LG. The Tmpgenc software products are good and reasonably priced but not free. None of their products gave any errors with any of these recorders.
so do you think there is a tmpgenc program that i could you use to demux discs burned on my DMR-EX85 without having the audio dropout problem ? (if so, which one ? are they mac compatible ?)
thanks,
mark
Originally Posted by trhouse
after some further investigation, i am finding (so far) that discs burned on the dmr-rx85 are being demuxed ok using mac the ripper.
mark
Does fixing Timecode breaks with MPEGStreamclip affect an image?
By danielmak in forum MacReplies: 1Last Post: 30th Mar 2011, 23:44 -
Odd breaks in video/audio authoured with DVD Shrink 3.2 & Imgburn
By bahjan in forum Authoring (DVD)Replies: 1Last Post: 1st Sep 2010, 13:46 -
Panasonic's AVCHD-Lite breaks MeGUI, DGtools
By trevmar in forum Video ConversionReplies: 31Last Post: 8th Dec 2009, 11:20 -
Looking for a Stand alone, cheap, DVD recorder, timecode on screen.
By AtomX in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Feb 2008, 16:10 -
Is there a muxer that can import video & audio timecode.txt files?
By oldpainlessuk in forum Video ConversionReplies: 1Last Post: 8th Jul 2007, 05:43
