VideoHelp.com Forum
    Hi everyone, something is bugging me.......I have been recording some footage lately in the outdoors with full daylight and then burning it to a DVD to see it for testing purposes.
    Typically a well lit video shouldn't go through "noise" problems, but the problem is that i do see some noise on the video, its not alot of noise but I can see it.
    I was told that in order to fix that and have clean video I need to adjust the IRIS manually, and not let the gain kick in.
    Is that true?
  2. Certainly, not applying gain and opening the iris wider will produce less noisy results. Using a slow shutter speed will, too.
    hey, thanks for the info.
    Im still sort of a newbie, I just need to make sure on some details, I know they might sound dumb because they are probably so easy to do, but I am a newbie.
    when you say opening the iris, you mean pushing it up to the limit in brightness where the video still looks natural right? ...like pushing up the "F 1.4 ...and so on numbers"?
    and when you say applying no gain, you mean keeping it at 0dB right?
    or am i being confusing?
    because the camera has variable numbers depending where Im aiming the cam.
    the shutter i think i can manage, its doesnt sound that technical, its just the iris and gain that i need to work on for better results.
  4. Member Cornucopia's Avatar
    The "GAIN" is something that is usually only used when you've set everything else as best you can, but (barring adding more light) you STILL don't have enough light for good exposure.
    The variables are:
    SENSITIVITY (GAIN is included here, as is real pixel sensor area/size)
    IRIS/F.STOP
    SHUTTER SPEED (although this is partially mitigated by the requirements of motion capturing)
    LIGHT LEVEL
    which all combine to give you:
    EXPOSURE
    Noise is added with increase in sensitivity (especially what "artificially enhanced" with GAIN)--much like film grain size vs. sensitivity.
    Noise gets "AVERAGED OUT" with slower shutter speeds
    You said that you burned this to a DVD -- is it possible that the "noise" you are seeing is encoding noise (artifacts)? What bit-rate did you encode at?
    Steve
    The variables are:
    IRIS/F.STOP
    LIGHT LEVEL
    EXPOSURE
    Steve
    Hi Steve,
    this is what i do.....
    when i transfer the video from the camera to the computer I use Pinnacle Studio, Full DV transfer.
    Then i use DVDit Pro to burn it on a DVD, I use the highest quality slow transcoding method to get better results, Im not sure what the bitrate is on that, but almost certain its 8000kbps.
  1. How 2 control video bitrate using ffpreset libx264
    By lindylex in forum Video Conversion
    Last Post: 3rd Jun 2010, 15:52
  2. Replies: 10
    Last Post: 11th Jan 2010, 00:57
  3. How do I control what decoders are being used to play video?
    By dimtim in forum Newbie / General discussions
    Last Post: 3rd Oct 2008, 05:47
  4. Selectable Output Control - MPAA's new control tactic
    By akrako1 in forum Latest Video News
    Last Post: 7th Aug 2008, 21:05
  5. Control wheel joystick for spinning through video
    By deanbrown3d in forum Computer
    Last Post: 28th Sep 2007, 01:05
