i have a compaq 3000+(2.16GHz) AMD Athlon XP processor 512 MB PC2700 DDR SDRAM menory, 160GB 7200RPM ultra DMA hard drive, this the info of my PC, im a noob to hardware, so im not shore if you need this info
i found this on ebay good or crap?
http://cgi.ebay.com/Digital-TV-Tuner...QQcmdZViewItem
Thread: can anyone recommend TV Tuner?
Do you want to to work well or do you just want to save money? Decide which is import to you. If you want a TV capture card that works well, you could buy a Hauppage model. The PVR-150 is pretty cheap and would do the trick for you. I'm highly skeptical that a card under $30 is going to be as good as Hauppage. I've never heard of this "brand", if it can even be called that.
Can someone recommend a USB style TV tuner product for my computer
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2010, 23:33 -
Can someone recommend a good USB style tuner device for me
By True Colors in forum CapturingReplies: 0Last Post: 31st Jan 2010, 14:12 -
Best PQ as possible via external tuner? Bypassing internal tuner/processor.
By Wizard256 in forum CapturingReplies: 0Last Post: 24th Jan 2010, 22:39 -
Recommend a Windows 7 compatible Tv Tuner
By zeek543 in forum Media Center PC / MediaCentersReplies: 5Last Post: 29th Oct 2009, 16:54 -
High Definition TV? Tuner or no Tuner?
By aturjans in forum DVB / HDTVReplies: 6Last Post: 17th Mar 2008, 07:31
Statistics
Newest guides
Latest tool updates
New media comments
