VideoHelp.com Forum
Results 1 to 12 of 12
    I am currently (trying) to use DVD Architect 3. I just recorded something from my DVR to a DVD+RW without chapters with the intention of adding my own chapters using DVDA. When I go to start a new project, I choose "Single Movie" and "Video_TS." I get the following message that does not allow me to go any further: "The selected file is not of the required type." In general, I know what that sentence means, but technically, what am I doing wrong?
    Thanks for your feedback,
    M_B_D
    Did you record in DVD mode or VR mode ?
    Have you tried using VOB2MPG to extract the mpeg stream from your disc for importing into DVDA ? (Note : you will have to copy the contents to your HDD to do this, VOB2MPG doesn't seem to like extracting from optical discs)
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    I recorded in VR mode. I'm not aware of what VOB2MPG is, so the answer is: no, I haven't tried that.
    M_B_D
    I don't believe DVDA will accept the output from VR mode directly. Very little will. VR mode is really designed to allow you to edit on your DVD recorder, and isn't much use for anything else. You will have to find a way to extract the contents to something DVDA likes, either a program stream or elementary streams. DVD Decrypter might be able to do this.
    Maybe I need to re-record it in video mode. DVD Decrypter didn't to the trick and neither did vob2mpg.
    M_B_D
    You have to transfer your VRO file to your PC and change the extension to MPG.
    I do this often and DVD Architect never complained.
    When you say "transfer," do you mean "rip?" I ripped the VR mode recording using DVD Decrypter. I tried to rename the file using an MPG extension with no luck. How did you do this? I saw a few past posts and read them, and I tried to follow what they were doing, also, with no luck. Another thing I did was use VOB2MPG and that didn't work. How is it that you are able to change the file to an MPG and have it work with DVD Architect?
    Thanks,
    M_B_D
    When I say transfer, I mean a simple Copy and Paste functions. Copy from your disk and paste to a folder on your PC.
    It has nothing to do with "luck".
    Please read this to learn how to properly change an extension:
    http://www.mediacollege.com/computer...on-change.html
    There is a further reading and stickys which may be helpful to you if you go to Forum > DVD recorders here:
    http://forum.videohelp.com/dvd-recorders-f28.html
    If you still encounter troubles, please describe what is a file structure on a disc from your recorder and do you let your recorder to finalize a disc.
    Okay -- I converted the file to MPG -- thanks for your help on that link. I still cannot get DVD Architect to accept it.
    To answer the other questions, I did not finalize the disc. Is that why I cannot get DVDA to work?
    I don't know if this matters, but keep in mind that I am using DVDA 3.
    Thanks,
    M_B_D
  10. Always Watching guns1inger's Avatar
    Make sure you have the latest version of DVD Architect 3 (3c is the current version). also, realise that changing the extension to mpg does not make it an mpg file. It is similar to an mpg, but contains extra data. This may be enough to throw DVD Architect off. You ideally need to demux the video and audio streams from your VRO files and go from there.
    I use DVDA 2.
    I believe that DVDA 4b is the current version.
    Simple renaming of VRO to mpg, works for me. Recordings are made on LG DVD recorder and I always finalize.
    Are you sure that you have renamed VRO file to mpg?
  12. Always Watching guns1inger's Avatar
    4b is the latest version of DVD Architect, but it is a paid upgrade from 3 to 4. 3c is the current version of DVDA 3.
  1. DVD Architect 5.0
    By Mr. Robinson in forum Authoring (DVD)
    Last Post: 4th Nov 2009, 10:59
  2. DVD Architect 4.0 Issue
    Last Post: 3rd Nov 2009, 13:47
  3. dvd architect burning issue
    By merray in forum Authoring (DVD)
    Last Post: 8th Nov 2008, 01:38
  4. DVD architect
    By romanstopme in forum Newbie / General discussions
    Last Post: 7th Apr 2008, 00:57
  5. DVD Architect help
    By monks19 in forum Authoring (DVD)
    Last Post: 23rd Aug 2007, 06:46
