1080i HDMI with high definition video upconversion.
It is a direct digital connection that can carry digital HD video as well as digital multichannel audio. By eliminating the conversion to analog signals it delivers perfect picture and sound quality, completely free from noise. HDMI is fully backward-compatible with DVI (Digital Video Interface).
Picture/Display
D/A converter : 12 bit, 108 MHz
Picture enhancement : Progressive Scan, High Def (720p, 1080i)
http://www.consumer.philips.com/cons...CSHP3HKFSESI5P
If by HD you mean HD-DVD then : NO
so..what does it mean by video upconversion.
sorry im kind of new at the whole thing.
thanks
An upconverting DVD player takes the resolution of a standard DVD disc which is 480 lines (progressive scan) and roughly doubles the lines to 720 progressive or 1080 interlaced resolution so that you get a high definition output on a high resolution screen. The best upconverting chips manage to do this while retaining detail, but they're essentially only blowing up a smaller resolution image. Real high definition content (Blu-Ray or HD DVD )is already encoded at the HD resolution, but you need a high definition DVD player to play these HD discs. Some people say that it's hard to detect the difference between a good up-converting DVD player and a HD or Blu-Ray DVD player.
All HDTV sets can receive a 720x480i or 720x 480p signal from a DVD and upscale to the resolution of the display screen.
Upscaling DVD players do a similar upscale to 1280x720p or 1920x1080i. Then the HDTV scales that to the "native display resolution"
Think of upscale as similar to "Full Screen" on your PC player. If you play a file at normal size, say 320x240 or 720x480 it will be a window on the desktop. If you invoke "Full Scrren", your display card upscales the video to screen resolution (e.g. 1024x768 or 1280x1024).
Digitising BD movies to play on media player
By khnguyen17 in forum Blu-ray RippingReplies: 6Last Post: 10th Mar 2012, 21:10 -
Blu ray player (Phillips BDP2700/12) won't play some movies.
By lema1610 in forum Authoring (Blu-ray)Replies: 8Last Post: 12th Oct 2011, 07:48 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Converting home movies etc to play on a DVD
By Andrew71 in forum Video ConversionReplies: 1Last Post: 19th Feb 2008, 07:51 -
ac3 avi movies don't play back in 5.1 on divx dvd player
By funkyspaceman in forum AudioReplies: 6Last Post: 20th Oct 2007, 16:11
