VideoHelp.com Forum
    Have just changed hard drive, minimum spec was 80Gb rather than 40. DVD still shows 40Gb after formatting drive, i.e. 52 hours recording time.
    Question: - is there a way of changing the setting in a service mode menu or a jumper setting on one of the circuit boards? If so, what is the process.
    Thanks in anticipation
    Phil O
  2. Member Krispy Kritter's Avatar
    All of the information and data I have found on this unit indicates that it only supports a 40Gb HDD. There are no known "hacks" or workarounds, the firmware and OS only support 40Gb.
    Google is your Friend
    Hi Phil O, what type of drive did you use to replace the old HS2 also wher did you get it. My HS2 is stuck in recover mode and changing the hard drive is my last option.
    Any help would be good.
    Bjazzz
  1. Panasonic DMR-HS2 power on failure
    By rmhartman in forum DVD & Blu-ray Recorders
    Last Post: 3rd Feb 2012, 14:19
  2. Panasonic DMR-HS2 - shuts down when I try to record
    By donmeyer2 in forum DVD & Blu-ray Recorders
    Last Post: 4th Sep 2008, 22:35
  3. Connecting Freeview to Panasonic DMR-HS2 Advice Required!
    By wilberfork in forum DVD & Blu-ray Recorders
    Last Post: 21st Aug 2008, 07:23
  4. Problem with Panasonic DMR-HS2
    Last Post: 20th Feb 2008, 15:07
  5. Replies: 6
    Last Post: 13th Sep 2007, 02:12
