I've been trying figure out why my 5140 won't show subtitles from DVD rips converted to Xvid. Here's what I did:
1) Ripped the Beverly Hills Cop Trilogy using DVDDecrypter in PGC mode,
2) Set up AutoGK for External Subtitles (have WinRAR as needed) & 1/3 DVD-R.
3) Ended up w/ idx, sub & srt subtitle files for each film.
4) Burned these and the avi files to a DVD+RW.
5) Loaded in 5140. Movies play but no subtitles.
If I press the "subtitles" button on the remote the OSD toggles between subtitles on & off, but none get shown during dialog scenes. The player's manual clearly states that sub's & srt's are supported and that they had to have the exact same filename as the avi (did so on the latter). I also tried giving the files 8.3 filenames (were long before) & reburning. Still no go. What would I be doing wrong?
Edit: As an afterthought, if I play the disc on my computer using Media Player Classic or Winamp (DShow), the subtitles DO show up. *scratches head*
Thread: Philips 5140, Xvid & Subtitles
HP: Transfigura! PM: Mr. Potter, what in Merlin's name is that?? *Gestures at white VW bug w/ a "53" on it.* HP: Well, professor, you did say to make a Beetle! PM: Hmmmpft! HP: My muggle cousin was watching "The Love Bug" before I left!
3. Are you sure you get a .srt from autogk??? srt subs are text files and it requires ocr to get them from a dvd.
I was thinking of the srt files inside the agk_tmp folder -- I tried one of those (renaming it to the same as the avi) & it didn't work. Although, I did find that the sub/idx combo will work on the 5140 as long as the visual scan (X times) isn't used. Then the subtitles disappear and won't return unless the film is restarted from the player menu (I was fast-forwarding through the opening credits to a dialog scene).
Regarding the srt files, two of them are found in the aforementioned agk_tmp like this:
MovieName.sub.cc.srt
MovieName.sub.cc.unicode.srt
In the case of Beverly Hills Cop (Part I), the "unicode" file has the lyrics to the opening song ("The Heat is On") enclosed in musical notes while the other file has them in question marks. I assume then that the "unicode" version allows extended ascii. Could these used for conversion? It would be nice to see the musical lyrics which the sub/idx version doesn't show at all.HP: Transfigura! PM: Mr. Potter, what in Merlin's name is that?? *Gestures at white VW bug w/ a "53" on it.* HP: Well, professor, you did say to make a Beetle! PM: Hmmmpft! HP: My muggle cousin was watching "The Love Bug" before I left!
Philips 5140 won't play retail DVD
By areynaldos in forum DVD & Blu-ray PlayersReplies: 10Last Post: 26th Jan 2009, 19:46 -
My Philips DVP 5140 has an annoying echo sound
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Sep 2008, 10:55 -
End of subtitle cut off with Philips 5982 or 5140
By fayewolf in forum SubtitleReplies: 0Last Post: 4th Sep 2007, 14:23 -
sound but no pic w/Philips 5140 + HDTV avis
By ezu0526 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 22nd Aug 2007, 21:52 -
sleep does nothing to a philips 5140
By BirdDaddie in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Jun 2007, 16:52
Statistics
Newest guides
Latest tool updates
New media comments
