Hi i have download mov file wich use dvcpro50 im trying to play them in quick time but i have only the sound what software can play or edit this video in windows environement ?
Results 1 to 11 of 11
Thread: dvcpro50 .mov video help
dv50? dx50 is divx 5.0.
DV50 is the double data rate 4:2:2 version of DV with 3:1 compression performance similar to Digital Betacam. It is a production format.
http://www.dvcentral.org/AreaDV50.html
Since your file is being reported as 720x480 (853x480), it appears to be 16:9 wide native.
Most prosumer editors have ability to import DV50.
Ah, thanks for setting me straight on that. What's the "50" stand for? ~Mb/s?Originally Posted by edDV
Yes, double DV rate or 50Mb/s.
DVCProHD is quad rate or 100Mb/s.
Digital Betacam 720x480i is less efficient at 90Mb/s.
im trying to insert it in adobe premiere but there is no video showing
Hmm, I had a look and even Premiere Pro needs third party support.
Normally DV50 comes in as SDI uncompressed rather than as a file.
http://www.google.com/search?client=...=Google+Search
Those were searches for
Premiere Pro DV50
DV50 codec
where do i found this external program ?
any idea
If you are using Premiere Pro, go look at their third party tools section.Originally Posted by kerm007
Mainconcept will be happy to sell you a standalone Directshow/VFW DV50 codec for $399
http://www.mainconcept.com/site/?id=537
They have a demo that leaves a watermark.
Matrox has a free dvcpro 50 codec at http://www.matrox.com/video/support/...codec/home.cfm
you have to register or try this direct link ftp://redirect:r45j99t3@video.matrox.com/private/release71/codecs.exe
Hope that helps.
You can also get the very good RAYLIGHT DV50 decoder (sorry, no encoder) for $95US.
Unfortunately, it's Panasonic that has VERY tight control over the codec, and they won't even let Apple license it for QT windows, yet.
Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4
By Baldrick in forum Video ConversionReplies: 102Last Post: 2nd Apr 2012, 10:35 -
PC does not render video camera HD .mov's well
By Whane The Whip in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 22:02 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
HELP! DVCPRO50 853x480 clips edit in Final Cut Pro?
By nato17 in forum MacReplies: 2Last Post: 16th Jan 2008, 22:49 -
By nato17 in forum Camcorders (DV/HDV/AVCHD)Replies: 8Last Post: 16th Jan 2008, 22:44
