My objective for learning DVD-authoring was to take two DVD movies, combine them into one DVD, the linked by a new menu to access either movie.
I've learned how to take a DVD and import it's video files authoring software to work with. I've also learned how to create a menu to link to both movies I've just imported.
My question is as follows; If is possible to import a DVD's existing menu into authoring software to be edited. If not to EDIT, then is it possible to create a new menu to link to the existing respective menus of the two DVDs I'm trying to combine into one?
Hi Noy2014,
Welcome to the forums.
DVDRemake Pro has a function whereby it will combine two DVDs, menus and all if you want to, and put a new menu at the front where you can select between DVDs.
DVDRemake Pro is extremely versatile and will, more than likely, be exactly what you need.
Good luck!There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Is any of this possible with Abode Encore 2.0?
Hoe to create a DVD menu with link to AVI files
By OggO1984 in forum Newbie / General discussionsReplies: 3Last Post: 14th Dec 2009, 15:01 -
How To create new dvd's with menu's from existing ones from standalone unit
By bidelman in forum Authoring (DVD)Replies: 1Last Post: 6th Oct 2009, 16:01 -
How to Create DVD Menu Template from existing DVD
By btodorov in forum Authoring (DVD)Replies: 3Last Post: 28th Jan 2009, 14:24 -
editng existing menu on DVD-R
By noki in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2008, 11:18 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
Statistics
Newest guides
Latest tool updates
New media comments
