    I'm new in capturing. im using WinDV, DVio and other apps but I always dropped frames. I already tweak and improve my system. The weird thing is I don't only dropped just one or two frames but 64 frames, nd another 64 frames for the next droped. I already follow the instructions about capturing dv. But nothing happens. Its the same as the first time i try.
    OS- WinXP SP2
    Memory- 768 MB
    HDD- 20 GB and 40 GB
    Snazio 1394 firewire Link
    can someone help me out...
  2. Member gadgetguy's Avatar
    Are you capturing to the same drive as the OS? Do you have two physically separate drives or a single drive partitioned into two? Are your hard drives SATA or PATA? What motherboard do you have? Are all of your hardware drivers and firmwares up to date?
    All of these things can contribute to dropped frames, as well as a bad cable and bad ports on either the cam or the computer.
    From your description it sounds to me like another process is taking control every so often and whatever it's doing lasts the same length of time as it takes to capture 64 frames. I would watch your CPU usage while you capture and see if you can identify a process that runs while you are dropping frames.
    Buy My Books
  1. VirtualDub Dropping Frames when capturing VHS
    By big_al_40 in forum Capturing
    Last Post: 4th Jun 2007, 16:57
  2. Dropping frames during capturing
    By mbekkali in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 7th Dec 2004, 22:17
  3. capturing hi res without dropping frames
    By calrankin in forum Capturing
    Last Post: 8th Jan 2003, 18:07
  4. Dropping frames when capturing audio
    By roh in forum Capturing
    Last Post: 10th Apr 2002, 18:08
  5. Dropping frames while capturing
    By joea123123 in forum Capturing
    Last Post: 5th Feb 2002, 14:21
About   Advertise   Forum   RSS Feeds   Statistics   Tools
