First off, I apologize, I wasn't sure what section to post this under.
I've got a Panasonic DMR-ES46V, I was trying to record some video from a camera onto a DVD+R (because thats what the manual says to use). Every blank DVD I put into the machine is unreadable, except for one, which it prompted me to format, and then said there was an error. I was wondering what I could be doing wrong. I'd really appreciate your ideas about this, thanks alot!
-Robert
First of all, make sure that your Panasonic can actually play +R discs. Secondly, you will most likely have to format the disc with your player, as you said you had. Why you got the error after the formatting I'm not sure though. Sometimes the quality of the discs themselves can present a problem for players.
Yeah, I'm sure it can play them, my dad makes slideshows, and has me burn them. I'm using some dvd's I got from the bargain bin at compusa, so they're 4x, might that make a difference? I also have some maxell DVD+Rs that are 8x. The player would not recognize those either. The one that it formatted seemed to be a random disk, as I pulled from the middle of the spindle (it was a 4x one). I tried the same disk after the following one failed. The one that I tried to format didn't work at all the second time (just like all the other disks).
I doubt it really. When was the last time that you got your player serviced? Sometimes having it cleaned expertly and checked thoroughly can solve these issues becuase lasers or trays can be out of alignment. I know it solved some of my reading issues.Originally Posted by DJThuht
Hah, never mind, I think the problem is solved...sorta... It doesn't play any disk whatsoever. So, I'm assuming the disks would have worked, supposing it could play store bought dvds. You think I could get it serviced? I didn't know they did that. Do you think this would fix the problem? If so, where would I go about getting it serviced?
A qualified electronics repairer should be able to do the job for you. Check your local yellowpages, or USA equivalent. I'm in Australia, so I can't direct you very well from here. Good luck though.Originally Posted by DJThuht
Panasonic DMR ES46V Remote Won't Work
By melvid in forum DVD & Blu-ray RecordersReplies: 12Last Post: 5th Sep 2009, 18:57 -
Panasonic DMR-ES35 fails to read discs
By lilblu in forum DVD & Blu-ray RecordersReplies: 7Last Post: 17th Jul 2008, 05:42 -
Panasonic ES46V Powers Off
By rgoubitz in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Apr 2008, 19:54 -
Two newb questions about the DMR ES46V
By Unikfreak in forum DVD & Blu-ray RecordersReplies: 6Last Post: 18th Oct 2007, 02:22 -
panasonic dmr-es46v doesn't work
By Delreek in forum DVD & Blu-ray RecordersReplies: 7Last Post: 28th Sep 2007, 05:25
