VideoHelp.com Forum
  1. I can't find the firmware for the european version of this DVD HDD recorder.
    Does anybody found it? I can download it from the service menu directly onto a DVD ( I obtain 4 files: main.bin, boot.bin, dev.bin and drv.bin) but I can't use them for upload to the DVD.
    P.S: I'm trying to change the HD
  2. Member Krispy Kritter's Avatar
    Is it really necessary to change the firmware just to install a new HD? Typically, you just replace the HD with another supported model.
    Google is your Friend
  3. as stated in the service manual, part of the firmware is stored in the HD, and it must be reloaded from the firmware CD when the HD is changed: the HD is used as a raw medium, and it has no partition (tested with linux!!)
  4. Nobody has tried to change the disk?
  5. Member Krispy Kritter's Avatar
    If that is indeed the case, then contact tech support to obtain the firmware DVD. They should also be able to answer any other questions that you have.
  1. Issue with Panasonic DVD-Recorder DMR-EH55
    By chudbeagle69 in forum DVD & Blu-ray Recorders
    Last Post: 16th Aug 2010, 12:56
  2. Panasonic DMR-EH55-Recording HD channels in full screen (16 x9)
    By Marshfish in forum DVD & Blu-ray Recorders
    Last Post: 28th Dec 2009, 22:05
  3. Panasonic DMR-EH55 - help to make it region-free
    By cyberspace in forum DVD & Blu-ray Recorders
    Last Post: 8th Oct 2009, 22:33
  4. "LOCK" in Panasonic DMR-EH55
    By jcrojasc in forum DVD & Blu-ray Recorders
    Last Post: 15th Dec 2008, 01:22
  5. Panasonic DMR-EH55/57
    By dvdpanrec in forum DVD & Blu-ray Recorders
    Last Post: 19th Dec 2007, 05:38
