I have already posted this, or at least I thought I did...but can't find the original. I'll try again. I converted 4 seperate avi files...home movies...to vob using Procoder 2. I now have 4 video ts folders each containg the same file structure. The 4 video ts folders are small enough to fit onto 1 dvd, and using nero express..it won't allow me to add anymore than 1 folder, stating that it cannot move video ts etc...or something to that effect. I guess the vob files have to be arranged in some way as to allow for them to be put together onto 1 dvd. Each folder has this:video_ts, video _ts.bup, vts_01_0, vts_01_0.bup, vts_01_1. I can understand why nero refuses to allow me to place all onto 1 dvd, as all of the file names are the same. If someone can tell me how to arrange the vob files it would be greatly appreciated.....thanks.
He's a liar and a murderer, and I say that with all due respect.
That guide will only work if you have full DVD structures to work with (ifo files etc). If you have encoded simply to VOB files then you will have to use an authoring tool to bring them together.
GUIForDVDAuthor is free and pretty easy to use.
TDA is not free, but also pretty easy.Read my blog here.
dvdr auto arrange
By JekylHyde in forum ComputerReplies: 6Last Post: 2nd Dec 2009, 08:34 -
Is it possible to re-arrange right click
By mn072065 in forum ComputerReplies: 2Last Post: 11th Jun 2009, 22:20 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
Burning MP3 onto CD - Software - Arrange files to my order
By UmmAddan in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2008, 21:48
