i've ripped (yes from a copy that I own) m2ts files from a movie. In order to play on my external HDD, i have to split the m2ts files. Here's the thing... I tried file splitter 1.31, but the problem i had with that is, with the 10 files it split, 3 of them worked while the other 7 said "data not support" or "data corrupted" I know there's a special splitter for this type of format. Can anyone help?
Try this little ditty...
http://www.sendspace.com/file/we9d8e
you know that helped a lot, but one file came up corrupt (out of all 10)... All other 9 parts played fine even with 5.1 audio on my PS3!!!
i'm going to change the file size split and see if that helps. thank you!
what utility would that be? It isn't there anymore.
to tell you the truth... i gave up on this a long time ago...
TSSplitter (if I recall), or TsRemux
domerdel
What method are you using now. I'm just getting into backing up my Bluray to HDD and just tried HDBDSplitGUI and it seemed to work but I don't get any video when I play the file back. Anyway after finding a howto about how to backup to HDD and have the PS3 play the files back I can't see a cheaper way to do this. 500GB HDD for $100, that's 20 movies at 25GB per movie, that's $5 per movie. Even disc will take a while to get that cheap. Can you think of a better way???
Why do some m2ts files play on PS3 while others in the same format don't?
By chrvi in forum Video ConversionReplies: 7Last Post: 12th Mar 2012, 13:31 -
Blu ray for ps3 with m2ts files
By ssangwan in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Feb 2012, 23:46 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 22:42 -
Playing multiple m2ts files on PS3 from a DVD
By dieselgg in forum Authoring (Blu-ray)Replies: 2Last Post: 20th Jun 2009, 09:47 -
advice for editing m2ts files from ps3
By acnescar in forum Newbie / General discussionsReplies: 6Last Post: 10th Jan 2009, 17:54
