VideoHelp.com Forum
    I tell ya I love it.
    Have some minor lines in the video, just transparent lines about half way down..
    Is there a way to find out what causes the lines?
    Been loving the card.
    I don't see the lines in the display, just in the recording, so I doubt it is the source. Recording from a composite source.
    I just wanted to drop a plug for the program gbpvr.com .com isn't in the name but you get the idea.
    If you are only using the 150's software then the serviced based recording is worth it alone. As long as your computer is on it will record or try, not so with hauppauge's software
    As far as your recording goes, I'm not quite sure but I do know that it over scans in its recording and I don't believe that the program shows you this on playback.
    Why do you think you have to be stealthy? gbpvr is in the Tools section here. You're allowed to mention it if you want to.
    To the original poster, do you see the strange lines when just playing the video through your Hauppauge? If so, then it's something in your source. What is your source? VCR? Any reason you're not trying S-video instead of composite, which is a higher quality video input?
    I don't think I have to be stealthy, the first time I came here and mentioned it the program wasn't listed in the section. I wanted to let the poster know that I don't have the answer but that it may be something of interest to them.
  1. Hauppauge 150: Odd Problem With Capturing
    By Tom Saurus in forum Capturing
    Last Post: 13th Apr 2011, 19:42
  2. capture VHS with Hauppauge PVR 150?
    By shun in forum Capturing
    Last Post: 24th Jul 2010, 18:11
  3. Hauppauge 150: Another Odd Problem
    Last Post: 12th Jun 2010, 11:22
  4. Hauppauge PVR 150 compatibility with my OS
    By GangstaRap in forum Capturing
    Last Post: 14th Mar 2008, 10:03
  5. Hauppauge 150, good or bad?
    By SerbianBoss in forum Capturing
    Last Post: 4th Dec 2007, 09:24
