Hoping someone can enlighten me here... I'm SO close to what I want...
I managed, with GREAT pains, to encode a movie from HD-DVD to a movie which is now 720p resolution (sized down to what my TV shows) and ac3 audio.
Basically, the stats are roughly:
Video: 1280x720 h264, 8000 Constant BR (I know this might be slightly high) Used Filter graph -> ffdshow --> .avs --> Virtualdubmod to encode.
Audio: 6-channel (5.1) AC3, derived PAINFULLY from the DD+ track.
OK... I finally get them encoded, and I multiplex them, first using MKVMerge GUI, because Matroksa supposedly works better.
In short... it works better. I can play it in Media Player, and if I jump around the navigation bar some, it will always go back in sync within a second or two. Everything looks great.
Ultimately, though, I know that .avi containers can be played by almost every program, like PowerDVD etc, which will NOT play Matroska .mkv's. So I multiplex the same streams into an AVI with AVI-Mux GUI.
The result seems the same, except now if I jump around with the nav bar, the audio is permanently de-synched.
Are there settings in AVI-Mux GUI that will help prevent this problem? Or should I stick to Matroska?...
EDIT: it just ocurred to me, this might not be a "newbie" question... :P
Results 1 to 1 of 1
How to Mux Subpictures to AVI/MKV?
By Velchiv in forum SubtitleReplies: 5Last Post: 9th Nov 2011, 16:26 -
mux h264/aac flv into h264/aac mkv
By Pitorasilo in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2011, 09:36 -
[solved]What is the proper way to fix an ac3 synch issue in a h264 mkv file
By yoda313 in forum AudioReplies: 0Last Post: 16th Apr 2011, 09:46 -
Mux h264.mp4 into avi container?
By ayim in forum Video ConversionReplies: 4Last Post: 11th Feb 2010, 06:18 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 10:10
