I need to change the region code of my internal Pioneer drive.
However, I now have only one more go at doing so before the drive becomes locked to a particular region. Is there a way around this?
Is there a way of flashing the region to All Region?
PIONEER DVD-RW DVR-109
Firmware Revision: A912
Build the drive into a PC, flash the firmware to RPC1, move it back into your Mac, reset the counter with Region X.
I don't have access to a PC.
The unofficial flasher utility for Mac only works upto model DVR-108. After that the programmer retired from the scene. So there is no unrestricted Mac flasher utility for your drive, only ones that run on dos/win/linux.
DVRFlash 2.2 should do it:
http://lasvegas.rpc1.org/
The RPC1 data file for the 109 is at
http://forum.rpc1.org/dl_firmware.ph...&manufactor=25
You do have to go into "terminal" to do this. I friend and I wrote some
user notes (dummy's guide, if you will). If you'd like a copy, drop me
a note with your e-mail address.
I understand that you need RegionX (from macupdate.com) to actually
reset the number of region codes to zero after making the drive RPC1.
Then you do your 6 changes again, run RegionX again, etc.Al Bloom
Yes Joachim S did this for us a while back:
Joachim posts Flasher
for Mac to xlr8yourmac.com in 2005.
and here:
Joachim's Flasher Direct
Region X direct link here."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Pioneer DVR-110D - Internal target failure
By tjax in forum DVD & Blu-ray RecordersReplies: 5Last Post: 27th Mar 2011, 17:41 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Pioneer DVR-118L internal IDE Burner ???
By blinky88 in forum DVD & Blu-ray WritersReplies: 1Last Post: 26th Sep 2009, 17:07 -
How do I update the firmware on my Pioneer 109 DVR?
By Boogie7910 in forum DVD & Blu-ray WritersReplies: 2Last Post: 26th Nov 2007, 04:44
