VideoHelp.com Forum
    how to encode my videoTS folder with ffmpegx , which contains serial films?
    exemple: 24h, Rome, desperate house wife,....
    when I encode my videoTS folder, which contains a serial film, I just have at the end the first episode !
    What is the tip to get all of the episodes ?
    thanks for your help
  2. Explorer Case's Avatar
    Are you encoding FROM a video_ts folder, or TO a video_ts folder?
    my files to be encoded are all in the videoTS folder
    I conclude it is from a video ts folder
    regards
  4. Explorer Case's Avatar
    DVD content in a video_ts folder is devided in 'titles' (between 1 and 99), in this case most likely one title for each episode. ffmpegX and most other encoding software takes one title at a time. Hence, you'd have to start an encoding for each episode. You can select the title to encode in the Video tab.
    as a matter of fact I do encode each file but I would like to select the video TS one time to encode all the files contained inside as I do with all classical movie to have a single avi file at the end.But with serial films this thechnique just encode the first episode and does not chain with the other ones in the video ts folder !!!
    I still do not have any simple solution.
    I am sure I am not the only one to encode this kind of popular serial film !!
    Can anyone help?
    regards
    If the DVD has been authored in a straightforward way, you may be able to join the corresponding VOBs together into a single file first, and then convert. However, this method is not guaranteed to work satisfactorily. And it is not quite as simple a process as you have been hoping for, but it may be worth a try to see if it works, and to see if it's acceptable to you.
  1. i cannot encode with ffmpegx
    By Se0r in forum ffmpegX general discussion
    Last Post: 24th Sep 2009, 12:38
  2. ffmpegX serial code - it never arrived!
    By mediajunkie in forum ffmpegX general discussion
    Last Post: 28th Aug 2009, 17:12
  3. FFMPEGX won't encode!
    By Kalasin in forum ffmpegX general discussion
    Last Post: 26th Jul 2009, 11:02
  4. What encode does FFMPEGX use for FLV?
    By pieman1968 in forum ffmpegX general discussion
    Last Post: 3rd Apr 2009, 13:16
  5. FFmpegX can't encode vobs
    By sgee34 in forum ffmpegX general discussion
    Last Post: 15th Jun 2008, 17:07
