VideoHelp.com Forum
    Hi
    Can anybody help? There is a problem in my system, whenever I run Premiere pro 1.5, my computer reset itself.
    Have anybody experienced it? Can anybody tell me the reason of this problem? I know it is not simple thing but I will be grateful to hear your idea.
    My system is:
    CPU: AMD Athlon 3000
    Ram: 1 GB
    VGA: 6600 GT-128MB
  2. If you are saying just starting the app restarts your PC, without taking any action in the program whatsoever, then the most likely fix is remove and re-install the app. Chkdsk and defrag wouldn't be a bad idea, either.
    Oh, yes, did it EVER work correctly?
  3. Member buttzilla's Avatar
    Also i like to add make sure your windows updates are up to date. Windows net framework.
  4. You could check the error logs and see if it gives any clues.
    Apologies if you already know how to do this, but if not,
    Control Panel, Administrative Tools, Event Viewer, Application.
    The Adobe user forum may well have some answers / solutions to this as well.
  1. Replies: 23
    Last Post: 1st Jan 2011, 21:38
  2. Have a new computer built to run CS 5?/ Help!!
    By Canon GL-2 Guy in forum Newbie / General discussions
    Last Post: 17th Aug 2010, 19:58
  3. error+restart while loading Premiere Pro
    By pixiecate in forum Software Playing
    Last Post: 22nd Oct 2009, 14:19
  4. error+restart while loading Premiere Pro
    By pixiecate in forum Editing
    Last Post: 22nd Oct 2009, 14:08
  5. adobe premiere pro keeps restarting my computer.
    By jasonkramer99118 in forum Newbie / General discussions
    Last Post: 4th Sep 2007, 15:31
